98 4 runner, clutch pedal popping/squeaking!!
Old Jan 15, 2008 | 01:59 PM
99lspwr's Avatar
Hi everyone!! B4 I get bashed I know all about the clutch squeak thread and so forth, but I read through the entire thing and couldnt find anything concrete on what mine was doing compared to everyone elses...
Anyhow, I do have the famous squeak when pushing the clutch pedal down but mine makes a popping sound when the pedal is pressed about 1/2 to 3/4 of the way down(not all the time, but about 1/10 times the pedal is pushed)... Is this a common thing too with the pedal problems that everyone has?? This sound would resemble an ankle or knuckle popping/cracking sound...It didnt look like these trucks had clutch pedal bracket problems from what I read...Do I just need to do the spring mod to clear up this type of symtom as well???? thanks everyone..
Old Jan 15, 2008 | 04:42 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
i bet it's just the stock spring binding up then popping. i'd just do the mod and you'll probably experience a nicer pedal feel. i had the pedal squeak when i first got the 4runner a year ago, and switched out the stock spring for a linear spring from carquest. it was $3!
still have the recoil- now without the squeak.
Old Jan 15, 2008 | 05:48 PM
toytech76's Avatar
nope! not the spring. The bushing the middle of the spring sits in is bad. replace your clutch pedal bushings. very common problem
Old Jan 15, 2008 | 05:58 PM
YM13's Avatar
I have a pretty noticeable squeak as well but mine isn't from inside the car it is coming from the boot on the side of the actual transmission under the car. I don't quite what it is...but look into that as well.
Old Jan 16, 2008 | 01:12 PM
99lspwr's Avatar
I actually got underneath it last night and the bushings actually seem to be intact, but that big pos spring thingy was binding up and making all the noise...I guess thats the thing everyone removes...huh??
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
