'97 4Runner sluggish
Old Jun 20, 2008 | 06:58 PM
jswilson's Avatar
My son's '97 V6 4Runner is running very sluggish.
Here's what we have done to try and fix the problem: new plugs, new cables, new front O2 sensor, new cat, clean MAF and throttle, reset computer, and a new fuel filter.
Any and all suggestions are appreciated.
Old Jun 20, 2008 | 07:53 PM
toytech76's Avatar
when was the tbelt last done? Ive seen something fall into the timing cover and make the belt skip causing the timing to be way off. Also, what plugs and wires did you use? Denso or nkg I hope. What does your air filter look like?
Old Jun 20, 2008 | 08:09 PM
kevin444's Avatar
yes i would also check for drive belts for slippage. Give it the seafoam treatment, and possibly run a compression check to see the health of the engine.
Old Jun 20, 2008 | 08:19 PM
jswilson's Avatar
Had the timing belt changed out 2 yrs ago, less than 20k miles on the new one. NKG I believe, but it was running great after I changed those. Approx 1.5 years ago.
I changed the first sensor in front of the cat. I think I replaced it with an O2 sensor. Just read that one is an a/f sensor. Is that correct?
Old Jun 21, 2008 | 04:58 AM
toytech76's Avatar
Not on a 97. They didnt start to change the #1 sensor to a/f sensors till 99. I would recommend having someone look at it. You will be time and money ahead instead of replacing every part you can hoping to fix it
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
