97 4Runner does NOT start at once.....?????
Old Jul 6, 2004 | 07:40 AM
LV_4Runner
Guest
Posts: n/a
(97 4Runner SR5 4X4 Auto 105K miles)
Often, when I turn the ignition key to start engine, there is NO response. All the lights and ding ding sounds come out normal. However, I have to attemp turing the key several times to turn the starter on. Once it is turned on, the started strongly cranks engine without problem.
When the starter does NOT respond, it is just dead silent, NOT even any signal rubbing sounds.
But, once the starter cranking, engine started immediately and everything seems just normal.
The frequency of this symptom is getting increased so as the possibility of getting stranded in some one else's parking lot....
Is it the sign of bad starter (doesn't look like so)?
or Is it contact problem? If so, can you advise where to look for the contact problem?
Or any other problem?
Thank you for your advise in advance.
Old Jul 6, 2004 | 07:46 AM
Marc's Avatar
Try checking your battery terminals. They may be loose.
Old Jul 6, 2004 | 07:50 AM
bamachem's Avatar
try checking the contacts on the starter where the cables attach. i had a loose one and it did the same thing. make sure they are nice and tight.
Old Jul 6, 2004 | 10:48 AM
Bigkahuna808's Avatar
I have this problome once in a while. I replaced my terminals on my battery and they tend to come loose.
Old Jul 6, 2004 | 04:31 PM
My99's Avatar
One of the most common problems is that starter contacts wear out on the starters ~ 80k miles an over, depending on use. If you've checked the easy stuff, it's probably this. Scour the archives, you'll see many examples of this problem in the past (myself included).
Old Jul 7, 2004 | 01:00 PM
FORANA's Avatar
I had the same problem. Clean battery terminals and tighten them. Then youre all good.
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
Jdgarrison
Oct 1, 2015 05:22 PM
camdenbuck
Jul 7, 2015 07:33 AM
JF9243176
Jun 24, 2015 04:53 AM
