95 Tacoma throttle problem
Old Dec 21, 2004 | 06:09 PM
pat2724's Avatar
2.4 L automatic when the truck sits or is cold I hit accelerator and the truck takes right off, when warmed up the peddle feels stuck, I have to push it harder than usual to get it going. I sprayed wd 40 on th throttle body and it works for a couple days then it feels hung up again.It does not happen ll the time.
Any ideas??
thanks
Old Dec 21, 2004 | 07:35 PM
Nic's Avatar
Nic
Sounds like the throttle body. I assume when you said sprayed WD-40 on it, you were talking about the (cable) outside of the throttle body. If that is the case, try cleaning the throttle body on the inside and see if that helps it.
http://www.4x4wire.com/toyota/mainte...throttle_body/
Old Dec 21, 2004 | 07:36 PM
jtm994's Avatar
try cleanin out the throttle body
Old Dec 22, 2004 | 02:38 AM
pat2724's Avatar
How do you clean it out? I never did that before.
Thanks
Old Dec 22, 2004 | 04:27 AM
Nic's Avatar
Nic
Check out the link in my post. It has instructions.
Old Dec 22, 2004 | 05:42 AM
jtm994's Avatar
it really easy all u need is a cloth some carb cleaner and a old toothbruth...it takes about 20 mins. just get all of the black out of it
Old Dec 22, 2004 | 06:36 PM
pat2724's Avatar
Thanks guys I cleaned it and it works better.
smthwsn357
May 1, 2024 07:28 AM
kazuya2416
Apr 5, 2024 02:17 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
