95 4runner only
Old Aug 18, 2004 | 09:18 AM
anthony1's Avatar
95 runner only
How many of you still running on original head gasket and how many miles you have now.
I haven't had the problem yet and it's 118K.
thanks
oops, can't seems to edit the thread title....
Pssst, all fixed CT
Old Aug 18, 2004 | 09:44 AM
ChickenLover's Avatar
I'm at 96k with the original head gasket with no problems.
Old Aug 18, 2004 | 10:11 AM
jht3's Avatar
had to have mine replaced last summer at 85k
Old Aug 18, 2004 | 04:57 PM
anthony1's Avatar
anyone else?
tt
Old Aug 18, 2004 | 06:55 PM
corvettelvr73's Avatar
Originally Posted by anthony1
anyone else?
tt
Ive bought my runner a year ago with 96,000 miles on it and I went to toyota to get it checked out and they said that the head gasket had been replaced under the "recall" thingy but you never know.
Old Aug 18, 2004 | 06:59 PM
Rugby10
Guest
Posts: n/a
112K on my 95 (which is not covered by the recall), I had to replace the cam seal about four months ago. Other than that shes been great, and I recently drove her from Nebraska to AZ.
Old Aug 18, 2004 | 07:25 PM
Marc P's Avatar
I bought mine at 80k--now at 125k. I dont think the heads have been off it, but I have no records.
Old Aug 19, 2004 | 03:53 AM
4mydogs's Avatar
I bought my 95 with 30K. It now has 130K. It was not covered by the recall. I have a slight leak -- not enough to be concerned about yet.
Old Aug 19, 2004 | 03:58 AM
cimahar's Avatar
Hello
1995 3vze 4runner 181k still original gasket, but I THINK it just started to leak antifreeze into the cylinders, it goes someplace without any leaks ever
carl
Old Aug 19, 2004 | 05:12 AM
jshanefadely's Avatar
Mine is at currently at 122K with no head gasket problem. However I'm dropping a new engine it this month anyway.
Old Aug 19, 2004 | 05:54 AM
flyAddict's Avatar
Anthony, I've had to have mine replaced twice. Once shortly after I got the vehicle, around 60K miles. A second time under recall, around 106K. The second time worked out well because the value cover gasket was leaking oil slowly on the engine, which made for smelly rides but the recall gave me an excuse to fix it with the recall covering most of the labor.
Old Aug 19, 2004 | 06:31 AM
Sbrut95's Avatar
Had to replace mine at about 130k.
Old Aug 19, 2004 | 09:09 AM
anthony1's Avatar
Thanks for sharing.....
My truck was built in Jan of 95 and it's not cover under the recall. I wonder when did they cut it off, when did they change the gasket on the engine building phase.
Is there anyone with late 94 that's not part of the recall?
My truck is fine so far but It's hard to believe that my truck is not cover because it was built in Jan 95.
Toyota also recall the 96 for Head Gasket which leaves me to wonder why they use the defective HG in 96 but not 95?
I don't know when does one expect the head gasket to leak as part of wear and tare and when it's the manufacture defect. I ran into someone with a 95 and he said he had to replace it at 85K and Toyota didn't cover it.
Old Aug 19, 2004 | 09:23 AM
??? Even if you have changed the head gasket is there a big possibility of it going out again??? Or did they change the head gasket design to remedy the prob.?
Old Aug 19, 2004 | 10:06 AM
gwhayduke's Avatar
215,000 miles, original headgasket, and still beating asphalt and dirt.
Old Aug 19, 2004 | 11:47 AM
jht3's Avatar
as i posted earlier i have a '95 (april manufacture date iirc) not covered by the recall. toyota customer care claims i got a good gasket
had it start leaking last june at 85k. toyota told me it "wore out"
did no good how many times i asked them to explain to me how a gasket wears out. and if i indeed did get a "good" gasket, why did it fail at 85k?
dealer is an old neighbor so he graciously met me 50/50.
Old Aug 19, 2004 | 03:56 PM
anthony1's Avatar
That' s great. Hope mine last as long as yours.
Old Feb 11, 2005 | 08:16 AM
green91runner's Avatar
Apparently, late 94 and early 95 models had the gasket 'redesigned', can't remember where I read this, or how it's changed exactly. I'm slightly hestitant to have it done from all the horror stories, and the bolts being 'stretched' and not re-sealing properly. I'm thinking it might end up making the situation worse, leaving me in a situation 50K down the road with a blown engine and Toyota sayng 'sorry, we fixed that problem'... (i know, worse possible scenario) really hoping it doesn't happen.
Wishing now that I blew the engine and just got a freebie from Toyota under the recall.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Poppie51
Jul 23, 2015 05:03 PM
