94 3.0 V6 ticking/nock sound through RPM's
Old Oct 18, 2004 | 03:17 PM
fiveofeen's Avatar
Its not very loud but always there, i did search and the only thing i hear is timing belt. anyone ever have lifters get a little slacked? i hear they are hydraulic, but it sure sounds like lifters. anyone out there with any tips? i'm gonna read through the haynes manual tonight.
Old Oct 18, 2004 | 03:19 PM
mastacox's Avatar
The 3.0 is a noisy engine, usually a little noise is nothing special, just the sound of gas being guzzled
Old Oct 18, 2004 | 03:26 PM
VolcomTacoma's Avatar
My 3.0 did this ever since I got it with 100k miles. It even got a new shortblock, adjusted valves, plus the timing belt and waterpump replaced, however it still ticked. It is just normal. My 3.4 has this same tick, but I am pretty sure its just the vsv for the emissions. If you search for "ticking" you will find a lot of info.
Old Oct 18, 2004 | 04:31 PM
ChickenLover's Avatar
Check the firewall plug at the steering shaft. It's common for it to wear out leaving a hole into the engine compartment, letting all that ticking into the truck.
Old Oct 18, 2004 | 06:29 PM
Waterboy's Avatar
Yep, spend $700 at the dealer getting the valves adjusted before I figured out that $15 fix.
Old Oct 19, 2004 | 06:41 AM
fiveofeen's Avatar
okay well that solves that, the haynes manual said the valve job is a challenge, i'd think it'd cost more than 700 at a dealer.
Old Oct 19, 2004 | 06:50 AM
Bumpin' Yota's Avatar
I have a T4RRM that goes through the valve adjustment if you need it.
Old Oct 19, 2004 | 08:25 AM
shiftless89's Avatar
check for exhaust leaks as well, I had a very small leak in the pipe near the manifold. i could only hear it under acceleration. made it a real bear to find in the driveway! (it made an almost clicking sound, like injectors/valves)
Old Oct 19, 2004 | 09:02 AM
roger's Avatar
Man, wish I had known that before I spent $450 to get my valves adjusted Oh well, live and learn I guess!
I might look into that firewall plug just to quiet things down in the cab.
Old Oct 19, 2004 | 11:14 AM
nunsa's Avatar
Are you sure it isn't the injectors? They're always loud on the 3.0!
Old Oct 20, 2004 | 12:05 PM
jay-q's Avatar
i second the exhaust leaks as well, have midas perform an free inspection for ya..... there is a gasket in the front of mine that was leaking.... after it was replaced the 'ticking sound' went away
Old Oct 20, 2004 | 02:57 PM
InFlames's Avatar
My 96 Tacoma was missing a bolt in a header flange that was causing a leak and making an annoying ticking/chugging noise under acceleration.. I replaced the bolts and nuts tightened everything up and locktited it and no more noises... now I just have to change my throw out bearing...damn annoying squeeking bull crap.
some drunk guy
Aug 3, 2021 06:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
