91 wheel bearing replacement questions
Old Feb 18, 2004 | 05:41 PM
red 59's Avatar
Im planning to replace my wheel bearings, but I have never done it to a 4x4. I have locking hubs and was wondering if I have to replace the gaskets and seals on the hubs. I know Im suppost to replace the seal behind the rotor. I also dont know what size the big adjusting nut is. Thanks.
Old Apr 9, 2004 | 05:42 PM
tystoy's Avatar
I have done the wheel bearings on my 91 4x4 a couple of times. Yes, I would say replace everything you can while you have the thing apart. I didn't replace the gaskets and ended up have to do it all over again.
Also, the cones behind the hub nuts can be removed by TAPPING the hub spacer with a hammer.
I believe the size of those nuts is 2 1/8" or 54mm but I can't remember for sure.
Good luck.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
