'91 4Runner Starter Replacement???
Old Nov 16, 2002 | 06:20 PM
BFG
greetings,......does anyone know the trick to replacing the starter motor on a '91 Toyota 4 Runner?
getting the damn thing off isn't the problem,it's getting it past the transmission/firewall that is .........
looks as though the only way is to lift the engine out,or remove the manifold and header pipe, but it can't be that hard to change one out can it,or am I wrong ? thanks!
Old Nov 17, 2002 | 12:57 AM
Jay's Avatar
Jay
It would come out of the wheel well if your refering to a 3.0L V6.
There are a few things that need to be moved in order to gain enough clearance to remove it. Various hoses, and wire harnesses etc....
In come cases I have found using a long pry bar and prying upward on the motor mount gave me just enough room to pull the starter out when and other attempts failed. I believe this is because the motor mount was sagging.
Good luck
Jay
Old Nov 17, 2002 | 06:28 AM
JustAnotherJodieFE's Avatar
What engine do you have? I just put my 2.4L & trans back in on Friday. I must admit that the lower starter bolt gave me more problems than most. Does the V-6 version have the small access panel to remove in the right front wheel well?
Old Nov 17, 2002 | 02:53 PM
BFG
Good luck
Jay
yes it's a 3.0L V6 ,sorry, I forgot to mention this (D'OH!).:pat:.....
I've actually looked at the wheel well as an option before,but it looked impossible to me at the time,........but I will take your advice and see if it works,it beats the hell out of removing the manifold, for sure!.........thanks!
Old Nov 17, 2002 | 03:03 PM
Jay's Avatar
Jay
Please remember to remove the negative battery terminal.
Jay
Old Nov 17, 2002 | 03:36 PM
BFG
Yeah ,it's a 3.0L V6 , I don't think it has an access panel in the well,but maybe, I might have to create one!.. ...heh!
Old Nov 17, 2002 | 03:47 PM
Jay's Avatar
Jay
You should have an access panel. I forgot to mention that.
It requires removing (4)10mm headed bolts. 2 of which are hidden beneath the rubber flaps.
Jay
Old Nov 17, 2002 | 04:53 PM
oldsub86's Avatar
The other thing that helps in removing the starter is to remove the heat shield on the exhaust manifold. There is a bolt and a nut on a stud. Take the shield off and it will give you enough room to pull the starter out of the opening in the wheel well after you have removed the access panel in the wheel well.
Randy
Old Nov 17, 2002 | 06:07 PM
BFG
Randy
thanks for the tip, I'll give it another try tomorrow as I did realize there was a access panel in the wheel well after all.......
I overlooked it due to all the undercoating and dirt covering it up.........
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Outsane
Jun 24, 2015 05:52 PM
infinityisfive
Jun 16, 2015 06:51 PM
Toyota Punk
Jul 1, 2002 05:44 PM
