89 4x4 gear ratio
Old May 7, 2004 | 07:24 PM
balljoint's Avatar
89 4x4 gear ratio
Trying to find out how to determine what rear end gears are in my truck.
It's a standard bed,1989,5 speed straight drive trans. Bearings are going in hogshead and have friend with parted out 1986, 2 wheel drive.Would like to just change it all, if possible. Did they make more than one ratio? Both are 22R.
Some help would be greatly appreciated .
TIA
Old May 7, 2004 | 08:33 PM
Glenn's Avatar
4wd and 2wd ratios are different. You probably have 4.10:1. Some 2wd's have 7.5" ring gears, and some have 8" ring gears.
Old May 7, 2004 | 08:34 PM
toy283's Avatar
4.10 with stock 225/75-15 tires, 4.56 with stock 31" tires. Nothing from the 2wd axle will swap with your 4×4.
Old May 7, 2004 | 08:35 PM
toy283's Avatar
In '86 all 2wd would be 7½" unless it is a 1-ton dually chassis.
Old May 7, 2004 | 10:02 PM
Glenn's Avatar
4.56 and stock 31" tires with the 22R series engine...I don't know if there are many of those from the factory. I think that most of those come with 3VZE engines, if not all of them.
Old May 7, 2004 | 11:13 PM
BLKNBLU's Avatar
http://www.off-road.com/toyota/tech/other/4_axles.html
Here's a good link to identify what you've got.
Old May 8, 2004 | 01:08 AM
toy283's Avatar
They're rare (may have only existed in '89) but my friend had that combo on his '89.
Old May 8, 2004 | 08:23 AM
Glenn's Avatar
I have that combo. But I had to put it together.
Old May 8, 2004 | 09:28 AM
kyle_22r's Avatar
i do believe that v6s had 4.56 gears with 31" tires and a manual transmission, 4.88s with auto
Old May 8, 2004 | 06:22 PM
toy283's Avatar
I'd seen somewhere that is was 31" tires, auto tranny, and 22RE engines that got 4.88's (thus the rarity of said gears). All other 31" tires got 4.56's.
Old May 8, 2004 | 06:35 PM
kyle_22r's Avatar
i don't think 22RE and auto had the option for 31s. all the oddball 4.88 diffs i've seen have had v6 carriers in them
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
