84 pickup 22re battery light and brake light on
Old Apr 29, 2003 | 07:16 PM
eroc1313's Avatar
Question 84 pickup 22re battery light and brake light on
ive had a 84 toy pickup with 22re for a year now and the batt and brake lights stay on always with engine running.I was told to change the voltage regulator and if a diode in the regulator it would cause the lights to come on.Wasnt the regulator!The alternator puts out 14.2vdc when running.The electrical system works great in the truck even with a large amp installed the headlights lightly dim with bass but that will happen with most vehicles witha true 160watt amplifier.I dont know were to look except the guage cluster or maybe the actual guages.Please help!
Old Apr 29, 2003 | 07:18 PM
eroc1313's Avatar
oops
i meant to say that if a diode was bad in the regulator it would cause the lights to stay on.I also checked the fluid in the brake cylinder,bled lines and checked the switch in the fluid reservoir
Old Apr 30, 2003 | 03:53 AM
fourwd1's Avatar
Your charge relay may have a problem. Also, check your master cylinder, if you're low on brake fluid, both lights will light.
Old Apr 30, 2003 | 05:52 AM
Shane's Avatar
Your alternator's brushes are probably shot. Also check the cable that runs from the alternator to the battery to make sure it's tight. The brake light comes on because of how Toyota wired the lights, when low on brake fluid just the one light comes on. What you have is a charging problem.
Old Dec 20, 2011 | 09:16 AM
scroungecat's Avatar
on my moms 85 2wd same thing brake and engine light flickerd and stayed on wenever it wanted changed the alternator never came back on it might of been internally regulated tho i cant remeber pretty sure tho hoe this helps
Old Dec 20, 2011 | 01:38 PM
James Woods's Avatar
I hope after almost 9 years that he finally found the problem.
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
BTOWN4RUNNER
Jul 24, 2002 03:30 PM
Mack
7
Jul 16, 2002 06:46 PM
