6 lug to 5. Possible?
Old Apr 14, 2004 | 11:55 AM
Designsbyme's Avatar
My fiances dad just bought a class 8 Baja truck for Baja 500 in June. He got sponsered by Goodyear and he has about 4 sets of wheels and tires he doesn't need and he said I could have.(Mickey Tompson Baja Claw 35", Pro Comp Extertian 35", and two others I forget) He said I could have them but the wheels are 5 lug. Is there a kit or some way to convert my 6 lug to 5 lug without spending too much $$?
BTW, I have a 95 Auto v-6
Old Apr 14, 2004 | 12:01 PM
SLC Punk's Avatar
I don't think there is a way to change a 6 lug to a 5 lug easily.
Old Apr 14, 2004 | 12:05 PM
superjoe83's Avatar
i would just buy some cheap steel wheels, and sell the 5-lug wheels to get your money back
Old Apr 14, 2004 | 12:17 PM
I thought about that, but the wheels are beadlocked.
Old Apr 14, 2004 | 12:22 PM
TDiddy's Avatar
I don't think you can legally drive beadlocks on the road. At least that was the case in CA. Maybe you could try selling them on Pirate.
Old Apr 14, 2004 | 01:26 PM
shazaam's Avatar
I thought they made this universal adapter thing, where you could plug a 6 lug wheel onto a 5 plug rim, and one for vise versa.
Old Apr 14, 2004 | 01:29 PM
That would sure be nice. I would have 4 sets of tires and wheels.
Old Apr 14, 2004 | 01:31 PM
shazaam's Avatar
Check with the people that make these ourageous 22", 24", 26" rims. For some of these wheels I know they come with universal adaptors. good luck
Old Apr 14, 2004 | 01:32 PM
shazaam's Avatar
and if you find it .. pm me, Ill give you the address of where to ship one of those sets.
Old Apr 14, 2004 | 02:04 PM
They are all 35s. Who knows, maybe I'll have a Yotatech give away or something. What in the world would I do with 4 sets?
Old Apr 14, 2004 | 05:45 PM
josh's Avatar
zesty
You could sell all 4 sets of wheels and you would have enough for one REALLY nice set of beadlocks that actually fit your truck.
Old Apr 14, 2004 | 10:26 PM
tenfourtyeight's Avatar
Yes, there is a way. There is something like this: http://www.protrux.net/products/acce...cers/index.htm
that goes on your 6 lugs, but only has 5 lugs on it. Don't know where to find one though.
Old Apr 14, 2004 | 11:07 PM
gn86r's Avatar
there might be an easy way to switch to 5 lug. go look at the Lexus LX 470, im sure that since its a toyota product you might be able to easily swap the hubs to make your rig 5 lug. really thats the only toyota truck that i know of besides the 2wd tacos or compact trucks that are 5 lug.
Old Apr 14, 2004 | 11:15 PM
Duffdog's Avatar
you sure can---there has always been a way to switch the nissan 6 lug trucks to toyota 5 lug just by getting a kit that switched the discs. in fact, why dont you try the easy way and get some 5 lug 2wd toyota parts and see if they just pop right on there.
T
Old Apr 15, 2004 | 12:17 AM
fourunnabilly's Avatar
Guest
Here are some links for you all...adaptors are everywhere these days. Truckin Magazine has a great connection as well, I would call them first. I dont have their mag here, but if you flip thru any copy, you'll see the add. Links below:
http://www.balancemachine.com/wheel_...el_spacers.asp
http://www.newsales.com/wheels/index.html
http://www.performancewheel.com/Index_Adapt.cfm
Those are just a few...run a search and you will get endless results. I think Wheeler's Off-Road in OR even carries some.
Good Luck.
Billy
Old Apr 15, 2004 | 05:26 AM
shazaam's Avatar
Many lexus parts while looking the same don't switch over. I had purchased the leather/wood steering wheel from an LX470 and tried to fit it on the runner. But while it did line up into the grooves on the steering shaft. The wiring schematics was completely different for the cruise control (even though the outside switch is the same). There were a couple of other things as well, bu this is just one quick example
Old Apr 15, 2004 | 09:17 AM
Supercharged's Avatar
No, the Lexus and Land Cruiser 5 lug will not help because they have a unique bolt pattern. They are 5X150mm, and no other vehicles use this pattern. What you will nee to find out is what the bolt pattern is on the 5 lugger and then go buy a set of adaptors to convert you 6X5.5 to the 5 lug pattern. However, this is only a band- aid solution since these adaptor are made for street cruising, not rock climbing so they have the tendencies to break under stress. Also, a true beadlock wheel is illegal for street use. As I recall when I was working in the wheel industry, a set of these adaptor can be purchased from any wheel accessories shop. They cost about $50 a piece from the wholesaler plus any profits tack onto them by the shops. Hope this helps.
SC
39 Thieves
Jan 6, 2017 01:08 PM
HiLuxer
Jan 6, 2016 11:34 AM
dbd6604
Oct 11, 2015 05:30 PM
Cycles
Sep 29, 2015 06:37 AM
sonorn67
Sep 19, 2015 05:39 PM
