5VZFE Flywheel install - manual trans
Old Mar 14, 2007 | 02:13 PM
funjumper's Avatar
I have a '96 5VZFE from a Taco that I am going to install into a '94 4runner. The motor did not have a flywheel installed when I bought it. I got a new/reman flywheel with the motor. The '96 FSM has minimal info about the flywheel installation. In the section regarding transmissions there is some mention of "front and rear carriers" used to attach the flywheel to the crank. I came across this page and I printed it out. Now I can't find the page, or the printout. I can't find an exploded view of the assembly. Page CL10 has the closest thing I could find. The motor was and will be attached to a manual transmission.
I have the motor, a flywheel, and a new set of flywheel bolts. What am I missing, if anything?
Do I just bolt it up and and torque it down to spec?
What is the torque spec?
Thanks for the help.
Old Mar 14, 2007 | 02:36 PM
hross14's Avatar
USE some Lock-Tight--always used it for my clutch/tranny jobs--imagine those bolts coming loose for whatever reason and then slicing through the bell housing and then maybe the trans tunnel.....Not trying to be dramatic but it happen to my old boss
Old Mar 15, 2007 | 09:45 AM
funjumper's Avatar
Bump bump
Old Mar 15, 2007 | 09:54 AM
MTL_4runner's Avatar
Sounds like you got everything. There should be 8 bolts for the flywheel and each one gets torqued to 63 ft-lbs on install. Also be sure you install a new pilot bearing before the flywheel goes on and use a tiny bit of loctite on each bolt to ensure they don't back out after torquing.
Old Mar 19, 2007 | 08:18 AM
funjumper's Avatar
1996 Tacoma FSM, Page EG92, bottom of the page, reads as follows -
begin quoted text>>>
18. A/T:
INSTALL DRIVE PLATE
(a) Apply adhesive to 2 or 3 threads of the mount bolt end.
(b) Install the front spacer, drive plate, and rear spacer on the crankshaft.
(c) Install and uniformly tighten the 8 mount bolts in several passes, in the sequence shown.
19. M/T:
INSTALL FLYWHEEL (See procedure step 18)
<<< end quoted text
I don't have any spacers. What do they look like? Does anyone have part numbers?
Old Mar 19, 2007 | 02:53 PM
BruceTS's Avatar
There are no spacers on the MT flywheel, like the AT.......
Sep 4, 2015 09:27 AM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
