5vz-fe blow-off sound
Old Jun 20, 2016 | 06:03 PM
bullfrogslayer's Avatar
I've got a 99 4-runner, 4wd, with a 5vz-fe motor. While freeway driving between 70 & 80 mph I get a blow-off sound ("pish"), similar to turbo blow-off, every 30 seconds or so. Any ideas?
Old Jun 21, 2016 | 12:15 AM
wyoming9's Avatar
Can`t really say I am not allowed to drive that fast!!
Are you losing any coolant ??
A leak in the heater core might do that as the vehicle flexes
Auto or Manual Transmission??
Old Jun 21, 2016 | 08:53 AM
Manual transmission. I recently replaced the heater core about 50k miles ago, though I guess it's possible I botched that job. The blow-off doesn't only occur at those speeds but it only occurs when under load and at 30 second intervals at those speeds. It happens at shorter intervals at lower speeds. I tried revving the engine at the same rpms but the blow-off doesn't happen unless under load.
Old Jun 21, 2016 | 09:05 AM
TheDurk's Avatar
Try a new rad cap.
Old Jun 22, 2016 | 12:14 PM
vasinvictor's Avatar
Maybe the turbo fairy came and visited you. I have nothing helpful to add
Old Jun 23, 2016 | 04:14 PM
Whaaaat? There's a turbo fairy?
Old Jun 23, 2016 | 04:34 PM
So I live in SoCal and my a/c is pretty much always on. But I turned it off for once and found that I only get the blow-off sound when the a/c is on. After I figured this out, I turned it on a few times and found it made the sound every time at the moment I turned on the a/c. So it looks like it could be the a/c compressor or condenser. Anyone else had this issue with their a/c? It's still blowing cold.
Old Jun 23, 2016 | 05:10 PM
akwheeler's Avatar
check the tension on your a/c belt. it's probably slipping a little when the compressor clutch engages.
Old Jun 24, 2016 | 08:28 AM
Yeah it normally will not make that noise. There is no pressure anywhere that's "blowing off", so you are probably hearing slipping belt. The tensioner takes a 14mm on the front bolt, just loosen it, then a 14mm on the bottom tensioning bolt. Might have to remove skidplate to get to it.
Elijahm23
Mar 16, 2023 07:22 PM
mreagen
Jun 16, 2016 08:13 AM
kapeket
Jun 16, 2016 07:40 AM
arlindsay1992
Jun 5, 2016 02:28 AM
