5VZ Cross Pipe Removal
Old Oct 28, 2009 | 01:00 PM
hross14's Avatar
And what i mean by drop is to lower the tranny--not remove it.
Old Oct 29, 2009 | 09:57 AM
VSU_4runnin's Avatar
Originally Posted by hross14
Here is my suggestion-
1. Tell wife to stay out of garage for 2 days and not ask any questions
2. Drink two beers
3. Remove the body mount Bolts and lift the body off the frame using jack a length of 2"X4". Keeps the cabin from getting dented
4. Support body off of frame--This is easier than you think--it just like putting in a Body Lift
4a. At this point you deserve a break--two more beers
5. Drop tranny and start cussing
6. Remove crosspipe and do what you gotta do.
7. Put it all back together making sure the everything is perfect--or you wil have to start over.
8. 12 pack of beer and then let the wife rub your feet for a change or do whatever floats your boat
Done
That, I believe is the best advice I have ever read on here. that is applicable to almost all work your doing on yer rig
Old Oct 29, 2009 | 05:43 PM
bwhyit's Avatar
Well, it turns out it wasn't so hard after all to get the pipe out. Here's what I did:
1) Remove the CAT pipe.
2) Remove the upper intake manifold. This give you a little more room to reach behind the engine.
3) Remove the exhaust manifolds.
4) Remove the bolts from the rear tranny mount and jack UP the rear of the transfer case. I jacked it up to the point I think I dented my floorpan a little.
5) After you've got all that out of the way you can roll the crossover pipe over the tranny bell housing and out the bottom of the truck, on the pass side. NO CUTTING REQUIRED.
It turned out to be pretty painless and I only needed one beer. It probably took me maybe 2 1/2 hours from start till I got the pipe out.
Old Oct 30, 2009 | 06:01 AM
hross14's Avatar
Hey good job--see we now all know another way to do it (take out the pipe that it).
Old Oct 30, 2009 | 06:28 AM
  #25
pfdaxe's Avatar
Did you throw a set of headers on while you were there.....would have been the perfect time...
Jcrawl94
10
Oct 24, 2015 04:34 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
romex1
Aug 10, 2015 06:21 PM
58rennur4
Aug 4, 2015 08:49 AM
