5VZ 3.4 V6 Head Gasket Poll
Old Jul 24, 2012 | 11:18 AM
  #41
Snowheeler's Avatar
Originally Posted by Potomacduck
BTW, the head gasket recall was only on the 1996 models.
95.5 tacos too. At least my friend had the HG on his 95.5 taco replaced through the recall - only to have it fail again after he sold the truck to another friend.
Old Jul 25, 2012 | 02:28 AM
  #42
vital22re's Avatar
totally a bro
I just replaced the head gaskets on a 96 runner auto for a friend. 160 on the clock but can't be sure its the original odometer. It failed at cyl 1
Old Sep 23, 2012 | 06:51 AM
  #43
Mojo_Risin's Avatar
Just attempting to build a database of blown head gaskets for the 3.4 5VZ V-6 engine. Please copy and paste this questionnaire into your reply post.
Year of your Rig: 1997
Rig Type (Taco or Runner or T100): 4Runner
Has your Head Gasket failed?: YES
Mileage at HG failure: ~210K (194k on Odometer but I've had larger tires on since 70K miles - so odometer is reading less miles)
Cylinder of HG Failure (if known): 6
Did your engine overheat prior to HG Failure?: Not prior - but started to leak coolant and get hot... was a symptom of it happening. So was rough idle at cold start... then finally white smoke for a few minutes after cold start.
Was the Head Gasket Recall work done on your rig prior to HG failure?: NO. Didn't qualify even though my build was 12/96
Old Oct 29, 2012 | 05:59 AM
  #44
bruced_500's Avatar
Year of your Rig: 2002
Rig Type: Tacoma double cab 4x4
Has your Head Gasket failed?: YES!!
Mileage at HG failure: 170,000
Cylinder of HG Failure (if known): right bank center
Did your engine overheat prior to HG Failure?: don't know
Was the Head Gasket Recall work done on your rig prior to HG failure?: Don't know I'm 3rd owner
Cheers,
Old Apr 18, 2013 | 05:51 PM
  #45
kel970's Avatar
Year of your Rig: 1996
Rig Type (Taco or Runner or T100):4runner
Has your Head Gasket failed?:yes
Mileage at HG failure:170K & 180K
Cylinder of HG Failure (if known):unknown
Did your engine overheat prior to HG Failure?:unknown
Was the Head Gasket Recall work done on your rig prior to HG failure?:unknown
Old Aug 2, 2013 | 10:53 AM
  #46
UKrunner's Avatar
Year of your Rig: 1998 engine in a 1997
Has your Head Gasket failed?:Yes
Mileage at HG failure:188,500
Cylinder of HG Failure (if known):3
Did your engine overheat prior to HG Failure?:Yes
Was the Head Gasket Recall work done on your rig prior to HG failure?:Unknown
Old Aug 2, 2013 | 04:39 PM
  #47
ARB1977's Avatar
Originally Posted by ubermoto
Howdy folks,
Year of your Rig:
Cheers,
Jeremy
Rig Type (Taco or Runner or T100): Tacoma
Has your Head Gasket failed?: No
Mileage at HG failure: 152000
Did your engine overheat prior to HG Failure?: Never over heated
Was the Head Gasket Recall work done on your rig prior to HG failure?: No recall on the HG
Old Aug 12, 2013 | 03:53 PM
  #48
Inverno4's Avatar
Year of your Rig: 2004
Has your Head Gasket failed?: external leak of coolant, probably fail soon
Mileage at HG failure: 172,000
Cylinder of HG Failure (if known): drivers side
Old Jun 24, 2015 | 09:33 PM
  #49
JF1's Avatar
JF1
Rig Type: 4runner
Mileage at HG failure:158,230
Cylinder of HG Failure (if known):4
Did your engine overheat prior to HG Failure?:No
Was the Head Gasket Recall work done on your rig prior to HG failure?: Unknown, Did Not Appear to have been when I replaced them.
Old Jun 26, 2015 | 12:31 PM
  #50
Kevin_A's Avatar
Year of your Rig: 97
Rig Type (Taco or Runner or T100):4Runner
Has your Head Gasket failed?:YES
Mileage at HG failure: 178,000
Cylinder of HG Failure (if known):6
Was the Head Gasket Recall work done on your rig prior to HG failure?:NA
When I checked, the heads were flat as could be, no machining neccesary, all valve clearances were within specs. I used Felpro MLS gaskets and have used it for towing this summer, so far,so good. If you are tore down this far, do yourself a favor and replace the starter contacts.
__________________
LCE_Performance
Oct 1, 2015 01:03 PM
sphealy
Sep 3, 2015 07:55 PM
kmchby76
Dec 5, 2006 12:15 PM
Cougarfreak
Oct 17, 2004 04:24 AM
93toy
Dec 30, 2003 09:11 AM
