5VZ 3.4 V6 Head Gasket Poll
Old Oct 21, 2010 | 01:20 PM
Matt_4runnin's Avatar
Year of your Rig: 1997
Rig Type (Taco or Runner or T100): 4runner (5vz-fe)
Has your Head Gasket failed?:yes
Mileage at HG failure:195,000
Cylinder of HG Failure (if known): unknown
Did your engine overheat prior to HG Failure?: Not while I've owned it
Was the Head Gasket Recall work done on your rig prior to HG failure?: unknown
Old Oct 30, 2010 | 05:28 PM
sinneDBTB's Avatar
Year of your Rig: 1990 w/ '99 taco 3.4
Has your Head Gasket failed?: yes
Mileage at HG failure: 4000 km after rebuilding bottom end
Cylinder of HG Failure (if known): n/a
Did your engine overheat prior to HG Failure?: no
Was the Head Gasket Recall work done on your rig prior to HG failure?: n/a
apparently HG's blw easy on yota's, starting to wish i swapped in a chevy.
anyone know if the HG's work the same for both sides? I have 2 rights...
Old Nov 26, 2010 | 06:55 PM
rworegon's Avatar
Year of your Rig: 1995.5
Rig Type (Taco or Runner or T100): Tacoma 5vz-fe
Has your Head Gasket failed?: Yes
Mileage at HG failure: 188,500
Cylinder of HG Failure (if known): Between 4 and 6 (driver side middle and near firewall)
Was the Head Gasket Recall work done on your rig prior to HG failure?:Yes, at 15,000 miles.
Noticed slight external leak and minor coolant loss. Teardown revealed internal leak - cyl. 4 and 6 being steam cleaned. Also, coolant water bypass tube leaking and filling wells in block, but no leak visible at 'tin' plate on rear of engine.
Old Jan 13, 2011 | 02:32 PM
msvphoto's Avatar
Sadly, another one...
Rig Type (Taco or Runner or T100): T100
Has your Head Gasket failed?: Yes, both (left much worse than right)
Mileage at HG failure: 159k
Cylinder of HG Failure (if known): 6 on left, not sure on right...maybe 3
Did your engine overheat prior to HG Failure?: Not at all, sudden failure.
Was the Head Gasket Recall work done on your rig prior to HG failure?: Not sure, but I think so. Have almost all records since new but don't have a receipt for HG replacement. When purchased (~ 5 years ago now) had local dealer run the VIN and they said it had been done. HG has one hole (which I understand means revision 1) which also indicates it may have been changed. Build date for the truck is 06/05.
Very bummed. Just found out yesterday both heads are cracked. Now looking for options for heads to get running again.
Old Jan 14, 2011 | 04:57 AM
  #25
BigBallsMcFalls's Avatar
1999 4runner limited 5VZFE, always Mobil 1 since 1st oil change,
always changed +-7500-8500 miles. 209000+ miles
does not lose oil, has zero leaks,
zero HG problems
blew my tranny cooler 9 months ago, milkshaked,
overheated but was able to stop before any warning lights
after that was fixed, still zero HG
or heating issues of any type.
thing is solid
never had even 1 engine issue.
Year of your Rig:1999
Rig Type (Taco or Runner or T100): Runner
Has your Head Gasket failed?: no
Mileage at HG failure: n/a
Did your engine overheat prior to HG Failure?: engine has overheated once but HG never failed
Old Feb 7, 2011 | 06:30 PM
  #26
dfoxengr's Avatar
isnt this recall over?
you guys can call toyota care and theyll tell you if your truck has had the work done.
Old Mar 9, 2012 | 09:13 AM
  #27
99SC4Runner's Avatar
Year of your Rig: 99
Rig Type (Taco or Runner or T100): 4Runner Limited Supercharged
Mileage at HG failure: 230k
Cylinder of HG Failure (if known): Don't know yet
Did your engine overheat prior to HG Failure?: No, never has overheated
Was the Head Gasket Recall work done on your rig prior to HG failure?: I don't think so.
Old Mar 10, 2012 | 10:53 PM
  #28
madbomber08's Avatar
Year of your Rig: 97
Has your Head Gasket failed?: No
Mileage at HG failure: 184k on the truck currently w/o failure
Did your engine overheat prior to HG Failure?: n/a
Just wondering how do you know your headgaskets fail without it overheating? Do you smell antifreeze in the exhaust, white in oil, what? I randomly decided to check my oil the other day and noticed very little milky substance at the bottom of my dipstick and the top underside of my dipstick. That was two days ago, so I have been watching the coolant and checking the oil after each time I drive it, and now I see nothing.
My main point is, what signs are there to look out for since most all of you have not experienced overheating?
EDIT: My 4runner has never overheated in the time that I've owned it.
Old Mar 11, 2012 | 09:07 AM
  #29
Utah Kid 4runner's Avatar
Year of your Rig: 96
Rig Type (Taco or Runner or T100): 4RUNNER
Mileage at HG failure: 238,000
Did your engine overheat prior to HG Failure?:unknown
Was the Head Gasket Recall work done on your rig prior to HG failure?:unknown
if i never did have the recall work done will they still do it? if not about how much $$ are we talking to only get a new head gasket put on?
Old Mar 11, 2012 | 09:27 AM
  #30
rworegon's Avatar
Utah Kid, call dealer with VIN #.
http://www.toyota.com/owners/web/pag...ources/recalls
Old Mar 11, 2012 | 09:30 AM
  #31
Potomacduck's Avatar
Year of your Rig: 1999
Mileage at HG failure: 328,000 no failures.
Cylinder of HG Failure (if known): na
Did your engine overheat prior to HG Failure?: The engine overheated once, replaced the fan clutch.
Was the Head Gasket Recall work done on your rig prior to HG failure?: BTW, the head gasket recall was only on the 1996 models.
Old Mar 11, 2012 | 11:09 AM
  #32
Originally Posted by rworegon
Do you think that if I have not had the head gasket serviced at the dealer when it had the recall they would still alow it to be done
Old Mar 11, 2012 | 11:29 AM
  #33
rworegon's Avatar
Never hurts to ask. Most say this campaign is closed, but every so often there has been a positive response.
Old Mar 11, 2012 | 07:38 PM
  #34
sinisstartacoma's Avatar
Head Gaskit Problems
I am new to this site, and I have 1997 toyota tacoma 3.4 v6. and at first had some issues with heater not working sometimes, then it started to overheat and boil over, and so i took it to radiator shop and that fixed the issue for about a week. one of my friends had told me to use "bars leaks" for temp fix if its the head gasket, now at this point, my heater doesnt work at all, and it overheats in about 15 min of driving, and i believe i need new head gasket, i just wanted some opinions on this, and if it is head gasket, what is aprox cost, cause i am not qualified nor have the time to do it myself, so i will take to my mechanic, just wanted to know some info on this. thanks.
Old Mar 11, 2012 | 08:30 PM
  #35
ThatGuy1295's Avatar
Year of your Rig: 2001
Mileage at HG failure: 191,000 no failures.
Did your engine overheat prior to HG Failure?: Not since I've owned
Was the Head Gasket Recall work done on your rig prior to HG failure?: N/A
Old Mar 13, 2012 | 08:12 AM
  #36
Those quick fix products are all a horrible idea. If you put them in your engine you could be looking at some bigger problems alot of them are thick like honey and can stop a leak but also can plug up oil gallies and critical parts that need lubercation.
Old Mar 13, 2012 | 08:59 AM
  #37
Jomoka's Avatar
Mileage at HG failure: 170K miles and counting without problems
Did your engine overheat prior to HG Failure?: bought at around 150K miles, not sure before then, certainly never even a whisper of trouble since
Was the Head Gasket Recall work done on your rig prior to HG failure?: Would not think so.
Old Apr 16, 2012 | 10:09 PM
  #38
Gonzo4Runner's Avatar
Rig Type (Taco or Runner or T100): 4runner limited
Has your Head Gasket failed?: no but head cracked in cyl #3
Mileage at HG failure: 190,000
Cylinder of HG Failure (if known): 3
Was the Head Gasket Recall work done on your rig prior to HG failure?: no
Talked with Toyota dealer mechanic and he stated that a cracked mid bank cylinder (3 or 4) was not unheard of and had seen it himself once or twice.
Old Jul 18, 2012 | 08:09 PM
  #39
Snowheeler's Avatar
Year of your Rig: 95
Mileage at HG failure: 240k NO FAILURE
Was the Head Gasket Recall work done on your rig prior to HG failure?: No recall on my VIN according to Toyota
Old Jul 20, 2012 | 03:34 PM
  #40
keoni1101's Avatar
Head Gasket Blown, no help from toyota
Mileage at HG failure: 146,000
Cylinder of HG Failure (if known): Dont know
Did your engine overheat prior to HG Failure?: Yes
Was the Head Gasket Recall work done on your rig prior to HG failure?: No, and i called toyota and they did not find any SSC X01 or Recall. They will not replace my head gasket
