5VZ 3.4 V6 Head Gasket Poll
Old Jan 9, 2010 | 07:33 AM
ubermoto's Avatar
Howdy folks,
Just attempting to build a database of blown head gaskets for the 3.4 5VZ V-6 engine. Please copy and paste this questionnaire into your reply post.
Year of your Rig:
Rig Type (Taco or Runner or T100):
Has your Head Gasket failed?:
Mileage at HG failure:
Cylinder of HG Failure (if known):
Did your engine overheat prior to HG Failure?:
Was the Head Gasket Recall work done on your rig prior to HG failure?:
Cheers,
Jeremy
Old Jan 9, 2010 | 07:35 AM
ubermoto's Avatar
I'll go first...
Year of your Rig: 96
Rig Type (Taco or Runner or T100): Runner
Has your Head Gasket failed?: Yes
Mileage at HG failure: ~195,000
Cylinder of HG Failure (if known): 6
Did your engine overheat prior to HG Failure?: No
Was the Head Gasket Recall work done on your rig prior to HG failure?: Unknown
Old Jan 9, 2010 | 12:38 PM
FogRunner's Avatar
Year of your Rig: 2001
Rig Type (Taco or Runner or T100):4Runner SR5
Has your Head Gasket failed?:No
Mileage at HG failure: Current milage is 250,000 with no heat gasket problems
Cylinder of HG Failure (if known):N/A
Did your engine overheat prior to HG Failure?:Never overheated
Was the Head Gasket Recall work done on your rig prior to HG failure?: N/A
I drive my 4Runner almost every day and most days I drive its 70-100 miles a day. I don't baby it and often kick it pretty hard when I need to pass someone on the freeway.
Old Jan 9, 2010 | 01:33 PM
raydouble's Avatar
Year of your Rig:2001
Rig Type (Taco or Runner or T100):4Runner 91,000 miles
Has your Head Gasket failed?:no
Mileage at HG failure:na
Cylinder of HG Failure (if known):na
Did your engine overheat prior to HG Failure?:na
Was the Head Gasket Recall work done on your rig prior to HG failure?:na
Old Jan 9, 2010 | 05:08 PM
stir_fry_boy's Avatar
Year of your Rig: 2002
Rig Type (Taco or Runner or T100): T4R
Has your Head Gasket failed?: No
Mileage at HG failure: N/A
Cylinder of HG Failure (if known): N/A
Did your engine overheat prior to HG Failure?: N/A
Old Jan 9, 2010 | 05:17 PM
Elton's Avatar
ive heard 96 had hg issues
Old Jan 9, 2010 | 05:31 PM
vital22re's Avatar
totally a bro
Year of your Rig: 92 with 97 3.4
Rig Type (Taco or Runner or T100): truck
Was the Head Gasket Recall work done on your rig prior to HG failure?: Not sure got motor with 100,000 on the clock.
I have heard the 96 motors had problem with hg... but the failure was coolant or oil leaking out from the head. Not into it.
Old Jan 11, 2010 | 04:44 PM
02SE's Avatar
The recall in 4Runners was for '96 and early build '97 5VZFE's. My 4Runner was built in July of '97. After calling to confirm my VIN, it wasn't included in the recall. No problems to date.
I believe the recall was for all 5VZFE's (4Runner, Tacoma, T-100) from inception to early build '97's.
Old Jan 11, 2010 | 05:35 PM
ubermoto's Avatar
Does anybody know what the latest build date was part of the recall? Was this when they switched to the MLS type head gasket? Asking cuz our '97 Taco is getting up in miles and I'm wondering if I should pre-emptively swap the engine out. I'd hate for it to fail and leave me stranded up in the hills. Can you tell if the HG is the graphite type vs MLS type without removing the heads?
Cheers,
Jeremy
Old Apr 8, 2010 | 09:07 AM
ajmcdonald23's Avatar
Year of your Rig: 1997
Has your Head Gasket failed?:Yes
Mileage at HG failure:352,839
Cylinder of HG Failure (if known):5
Did your engine overheat prior to HG Failure?:No
Was the Head Gasket Recall work done on your rig prior to HG failure?:No
Old Apr 8, 2010 | 05:38 PM
Midget96's Avatar
According to my documents from the original owner, my super early '96 (built Dec. 1995) had the head gaskets replaced at 28K miles because they were notably leaking coolant on the exhaust manifolds.
I would say if they didn't fail in the first 50-75K miles, then you're probably not going to have any dramatic failure down the road.
Old Apr 14, 2010 | 06:15 PM
monster900's Avatar
Year of your Rig:1996
Rig Type (Taco or Runner or T100):4runner
Mileage at HG failure:156000
Cylinder of HG Failure (if known):?
Did your engine overheat prior to HG Failure?:Yes
Was the Head Gasket Recall work done on your rig prior to HG failure?:Yes, this is the second one it has blown since new. Also lost a cracked head this time. Really sucks.
Old May 26, 2010 | 06:53 AM
slorunna's Avatar
Mileage at HG failure:183000
Cylinder of HG Failure (if known):5 & 6
I have heard that a common cause of HG failure in the earlier 3rd gen models is commonly due to the exhaust manifold and cat. The y-pipe connects behind the engine along the seam between heads and block. If the cat craps out, there is insuficient dispursing of exhaust gas (aka heat build up) right along the the location of the head gasket. I believe it because my runners gasket blew on my rear most cylinders.
Old May 26, 2010 | 07:02 AM
badattitude's Avatar
Year of your Rig: 1999
Rig Type (Taco or Runner or T100): 4Runner
Old May 26, 2010 | 09:05 AM
Yota Yeti's Avatar
Year of your Rig: 97
Mileage at HG failure: Current Mileage - 183,450
Cylinder of HG Failure (if known):NA
Did your engine overheat prior to HG Failure?:NA
Was the Head Gasket Recall work done on your rig prior to HG failure?:NA
Old May 26, 2010 | 10:54 AM
Mauzer's Avatar
Mileage at HG failure:N/A
Cylinder of HG Failure (if known):n/a
Did your engine overheat prior to HG Failure?: no overheating
Old Sep 8, 2010 | 04:19 PM
japanimation's Avatar
5vz-fe bhg 96 t100
Year of your Rig: 1996
Rig Type (Taco or Runner or T100): T100
Mileage at HG failure: 109,000 miles
Cylinder of HG Failure (if known): Passenger side bank, haven't taken the head off yet.
Did your engine overheat prior to HG Failure?: No, sitting in the driveway, tried to start it for work one random morning. FML
Was the Head Gasket Recall work done on your rig prior to HG failure?: If it was, it was prior to when I got it at 60,000 miles.
I also have a Toyota 7M motor that BHG'ed. Just finished putting it back together. The T100 was babied with full synthetic oil every 4-5k mi. This was supposed to be my "old reliable" while fixing the supra. Now I put all my eggs in one basket, toyota basket, and have no ride at all. That's what you get for paying the extra $ for the toyota name/reliability! Regrets I've have a few ...
Old Sep 10, 2010 | 06:57 AM
naksukow's Avatar
Lol 7m is notorious for bhg.
Old Sep 11, 2010 | 08:33 AM
y2kltdsport's Avatar
2000 4 runner 250K no problems whatsoever
Old Sep 11, 2010 | 05:12 PM
lol, notorious b/c boost pressure causing most of the BHG ...
and now the same rep can be had for the 5VZ.
The 7M lasted to 200,000 miles while being pushed rather hard before BHG.
The 5VZ made it to 11X,000 mi but was babied. Maybe it's time to push the 5VZ.
I didn't see any recalls on the 7M though, (maybe I somehow missed them) but I see quite a few posts stating ppl got their 5VZ HGs replaced as part of a limited recall campaign.
