#5 cylinder misfire on 01 Tacoma
Old May 19, 2015 | 06:41 PM
Dljy's Avatar
Truck started idling rough yesterday at traffic light and starts jerking around 45 mph, code is P0305. Ohmed out the injector for #5 cylinder (26.4) ohms, engine was warm when I checked, is this in spec?
Old May 20, 2015 | 03:38 AM
Texas_Ace's Avatar
You will need to look in the FSM for the ohm spec. If it checks out start simple. replace the spark plug with an el cheapo from the parts store and see if things improve.
While at the store rent a compression tester, is the spark plug doesn't help then run a compression test just to rule things out.
If that checks out then it must be fuel if the issue is only with #5.
Old May 20, 2015 | 03:47 PM
maachine's Avatar
ohm out the spark plug wires too. all 3 should be fairly close. if one is way off from the others, that's probably your issue
Old May 20, 2015 | 07:42 PM
Dljy's Avatar
I ohmd out the injector with the motor cooled off, read15 ohms, I ohmd out the injector for #3 cylinder, 14.6 ohms, so maybe I'm on the wrong trail.
Old May 21, 2015 | 02:09 AM
dropzone's Avatar
Fossilized
did you find what the spec was in the FSM?
Old May 21, 2015 | 05:08 PM
Dljy's Avatar
I saw on another thread that 14-16 ohms is good, I pulled the coil pack off, but the boot didn't come with it just the coil and a long spring, so now I have no clue as to how far does the spring fit in the boot and also does anyone know what the spec is on the resistance of the coil?
Old May 21, 2015 | 05:21 PM
DavidLovesToyotas's Avatar
Any oil leaks?
Old May 21, 2015 | 05:34 PM
Dljy's Avatar
No, may I ask what would that cause?
Old May 21, 2015 | 05:48 PM
Ive heard an oil leak in the top end(rings, valve seats) can cause your plug to foul and cause a misfire. http://www.obdii.com/articles/Diagnosing_Misfires.html Sent from my iPhone using YotaTech
Old May 21, 2015 | 05:52 PM
Dljy's Avatar
Gotcha, didn't get an opportunity to pull the plug out today, due to thunderstorms, it tripped me out yesterday when I pulled the coil pack out of the boot( on accident)
Old May 22, 2015 | 03:34 AM
Texas_Ace's Avatar
If the coil fell apart when you tried to remove it then it is a good bet that you found the issue. Would easily explain why the misfire was on #5 when the coil feeds 2 cylinders.
Move the coil to another cylinder and see if the issue follows it.
Old May 23, 2015 | 05:38 PM
Dljy's Avatar
Problem fixed
Swapped #5 coil pack with #3 and re scanned problem stayed on #5 cylinder, replaced plugs, wires, runs like a dream, Thanx guys!
Old May 26, 2015 | 12:56 PM
maachine's Avatar
probably a bad plug wire for sure. i had a similar issue not too long ago myself. changed the spark plugs cause they needed to be changed anyway, which didnt help. then ohmed out the spark plug wires and found a bad one.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
256mbaker
Jul 31, 2015 06:45 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
