4wd dash light not working
Old Feb 15, 2014 | 09:30 AM
nix84yota's Avatar
So i searched and couldn't find anything, everything I found was about all dash lights not working. Well, all other dash lights seem to be working fine, just not the 4x4 one.
My 4wd is working but the dashlight no longer comes on when engaged. It use to but not as of lately, any ideas? Is it just a burnt out bulb in dash or some sort of relay, comp issue or something...??? TIA
Old Feb 15, 2014 | 10:33 AM
TheDurk's Avatar
What year are you? (Putting your info in your sig helps immensely to get the right feedback). I assume it's not an '84! If so, you are in the wrong place.
Assuming NOT '01-'02 (electric front diff actuator), three possibilities:
1. Bulb
2. Sending switch on front diff.
3. wiring in between.
No relay or computer involved if 4wd is indeed working. #2 is most likely.
Old Feb 15, 2014 | 02:48 PM
nix84yota's Avatar
1. Bulb
98 limited 4runner
Old Feb 15, 2014 | 04:59 PM
nix84yota's Avatar
UPDATE: So even though it seemed my 4wd was engaging both axles and just not turning on the dash light, it wasn't. It was only enagaging the rear. I read about the vacuum lines and figured id check them out since its easy, one of the vacuum lines was pulled off, BAM, piece of cake!
I thought my 4wd WAS engaging. my bad, mahalos.
Old Feb 15, 2014 | 05:13 PM
nix84yota's Avatar
pau pau pau pau pau!
Valvoman
Jun 28, 2015 02:45 PM
gog1968
Jun 22, 2015 05:55 AM
Taz22R
Jun 21, 2015 04:44 PM
ShaunKris
Jun 17, 2015 04:33 PM
