4th gen V8 owners...low range 4WD ?
Old Jul 18, 2003 | 06:34 AM
nrgetic99's Avatar
Ok,
I am officially confused.
For those of you with 4th gen Runners with the silky V8, can you have a 4WD with low range.
The web site and brochure are confusing...
David
Old Jul 18, 2003 | 07:07 AM
The V8 with 5 speed automatic is full time AWD all the time. To put it in 4Lo simply shift to N and turn the knob. The 4Hi/4Lo knob is located to the left of the A/C controls in the center of the dash.
JGage's Avatar
Do you mean, can it be switched from full-time 4WD/AWD to 4WD Lo ?
If the the answer is yes, but it has to be in neutral to make the switch.
Old Jul 18, 2003 | 07:12 AM
It must be in Nuetral to shift to 4lo
Old Jul 18, 2003 | 07:32 AM
nrgetic99's Avatar
Cool,
The wording of the brochure is confusing...
For a minute then I thought I would have to give up the V8 :pat:
David
Old Jul 18, 2003 | 07:47 AM
SLC Punk's Avatar
Does it have to be in Neutral to go into 4low?
Old Jul 18, 2003 | 08:39 AM
Slib77's Avatar
It has to be in neutral. You can only use the DAC in 4LO only. FYI
Old Jul 18, 2003 | 08:57 AM
Sac State's Avatar
You can only use 4Lo w/DAC when the transmission is also shifted to 'L'. DAC does not work in 4Lo with the transmission in 'D', '3' or '2'. It takes a few trys to get the transfer case to un-shift from 4Lo back to 4H, which can be annoying while on a trail, etc.
Old Jul 18, 2003 | 08:59 AM
Good Times's Avatar
v8 4x4 = fulltime 4 wheel drive with 4lo/4hi option
v6 4x4 = parttime 4 wheel drive with 2hi/4hi/4lo option
as for the dac... it's a pos that works but damn it's annoying... beeping n stuff... i personally don't like it but hey atleast i know it works
to engage 4lo in any system, you must be in neutral once in 4lo you can engage the dac (for those who have em).
Old Jul 18, 2003 | 09:35 AM
Sac State's Avatar
GT-What happened to your Runner avatar?
Old Jul 18, 2003 | 09:37 AM
Good Times's Avatar
changing it around ..
as soon as i get a better pic (lifted ofcourse) i'll replace it again..
Old Jul 18, 2003 | 09:42 AM
Sac State's Avatar
What lift did you decide on?
Old Jul 18, 2003 | 09:45 AM
Good Times's Avatar
Downey - only cuz they're close to where I work and I'm their sucker (testing purposes). They already have the front coilovers done and ready to install. They're still waiting on the rear coils and they're set. Just waiting for their call to drop off the 4runner so they can install it and make sure everything fits and works properly b4 they hit the shelves.
also I'm working with King Shocks on their awesome coilovers too (hehe so i'll have two...) but anyway that's still awhile away cuz i told them it'll be after Downey (which they didn't mind).
Old Jul 18, 2003 | 10:48 AM
02Runner's Avatar
So what you're saying is it has to be in nuetral before I shift?
Old Jul 18, 2003 | 10:49 AM
02Runner's Avatar
JK
Old Jul 18, 2003 | 11:02 AM
Sac State's Avatar
yeah, and you can be doing 65mph when you finally do decide to shift. JK
Old Jul 18, 2003 | 11:09 AM
Slib77's Avatar
Just got an E-mail from Pro-Comp. They are working on a 4th Gen. lift. They say that they are doing mass R&D and that they should be available within a year.
Serge
Old Jul 18, 2003 | 03:07 PM
Good Times's Avatar
wow 1 yr ehe... not bad!! lol
Old Jul 18, 2003 | 03:21 PM
Slib77's Avatar
Way too long to wait for a Pro-Comp.
Fab-Tec has no plans as of yet.
kawazx636
Oct 6, 2021 03:03 PM
icentropy
Sep 10, 2015 05:03 AM
landrunner
Aug 5, 2015 09:18 PM
CruisingBama
Nov 2, 2003 12:00 AM
