4th Gen. CLANK!
Old Feb 22, 2004 | 03:15 PM
Yosmany's Avatar
4th Gen. CLANK!
Every so often, when I mak a sharp "U" turn or a really tight turn, where the body kinds rolls into the oppisite side of the turn I hear a clank. It sounds like it is coming from the A-arm/front suspension assembly. I almost sure of this. I took it into the dealership, and the couldn't reproduce the noise, but they said that they inspected my front suspension and that everything checked out O.K. It's done it twice since then.
Has anyone else ever heard a clank/pop in the front suspension when making a hard or sharp turn in their 2003 or 2004?
Is this normal, and I am just exceeding the limitations of my steering components?
TIA guys!
Old Feb 23, 2004 | 01:26 AM
02Runner's Avatar
Yosmany have you lifted the truck?
So far I haven't had anything like that on my 03.
I did have it "clank" on my 02 after lifting though!
Doug
Old Feb 23, 2004 | 04:08 AM
CTB's Avatar
CTB
Do the 4th Gen's have steering stops? If so, maybe you are just rubbing those.
Old Feb 23, 2004 | 07:31 AM
TechWrench's Avatar
I have a stock '03, and have had that happen twice. It happened both times while making a sharp left turn into a driveway. I've looked, and can't see anything rubbing or hitting, but it is hard to duplicate suspension compression while sitting still. My friend who also has a stock '03 (V8) has also had it happen to him several times. His dealer checked and didn't find anything. I will be looking closer when spring arrives.
Old Feb 23, 2004 | 07:54 AM
Yosmany's Avatar
It sound like you have exactly what I have. My biggest concern is that I don't want anything to happen after my warranty has expired. But if it is normal then maybe I should just ignore it for right now.
Old Feb 23, 2004 | 08:22 AM
tenfourtyeight's Avatar
If it's the steering stops, just put some grease on them. If they are front and back, be sure to put it on both.
Old Feb 23, 2004 | 09:19 AM
Sil23's Avatar
TIA guys!
Could it be this problem as stated on the NHTSA website..
Make : TOYOTA Model : 4 RUNNER Year : 2003
Service Bulletin Num : SU00503 Date of Bulletin: AUG 28, 2003
NHTSA Item Number: 10003566
Component: SUSPENSION:FRONT
Summary:
SQUEAK NOISE FROM THE LOWER FRONT AREA OF THE VEHICLE OVER SHARP IMPACT TYPE BUMPS. *TT
Old Feb 23, 2004 | 10:36 AM
Yosmany's Avatar
Summary:
I'm not really sure, because it's not a squeak and it only happens on sharp turns. Is there a TSB on this bulliten?
Old Feb 23, 2004 | 10:50 AM
Sac State's Avatar
I have a clunk, happened once. It is not a squeek. A squeek is associated with the shocks as you drive over a speed bump. This noise was caused by the wheels being turned sharply with minor front end dive. I was turning hard left into my driveway at about 10mph.
Old Feb 23, 2004 | 10:56 AM
Yosmany's Avatar
That's it, that's the one. Do you know cause and prevention?
Old Feb 23, 2004 | 11:10 AM
93Toy_Yota's Avatar
Question Same problem, on a 93
I have the steering stops on my 93 p/u, and I have greased them, but they keep doing it. Has anyone ever gotten the noise to stop, short of cutting them off? Also, would rubber around the bolts and steel plates stop it from sounding like the wheels are coming off? TIA
- Josh
Old Feb 23, 2004 | 03:04 PM
JGage's Avatar
I've had it happen once or twice. No big deal IMHO and I have like 21k miles on my truck.
Old Feb 23, 2004 | 04:03 PM
kid's Avatar
kid
Could it be a rear stabilizer bar bushing? Have heard this before.
~Kid
Rickstwowheels
Sep 29, 2015 02:23 PM
themightykhoner
Sep 18, 2015 02:28 AM
AlexJet
Sep 14, 2015 09:00 AM
icentropy
Sep 10, 2015 05:03 AM
ahriman
Aug 1, 2015 10:38 AM
