4runner without a towing setup
Old Apr 25, 2006 | 05:56 PM
chadbobb's Avatar
Ok, i am curious, i just got approved by my bank for a loan and i am ready to buy a 4runner. One thing i need to know though, is when i get it, it its not already set up for towing what all do i need? What is part of the 4runner towing package? Do i just need to buy a hitch? Anything else really important?
Thanks a bunch
Old Apr 25, 2006 | 06:29 PM
Elton's Avatar
the towing package is a hitch and the trailer wiring harness
Old Apr 25, 2006 | 06:39 PM
chadbobb's Avatar
so what all would i have to buy? and do you know anyplace i could buy it for a 3rd gen 4runner?
Thanks
Old Apr 25, 2006 | 06:44 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
we've gotten them installed on several vehicles at UHaul and it works perfectly fine. some trailer stores may be able to do it and i know an offroad shop would be able to do it. you have to buy the hitch and the harness.
Old Apr 25, 2006 | 08:03 PM
khaug's Avatar
Thanks
AFAIK, all 3rd gen 4Runners came with a hitch receiver and flat-four lighting connector as standard equipment. All you should need is a ball mount and a ball. Be sure your ball mount has a drop that's appropriate for the trailer you're going to tow.
Toyota rates the V6 3rd gen 'Runners for towing up to 5,000 lbs. Toyota recommends you tow with the overdrive turned off, and I heartily second that advice. I owned a '98 Limited for 75,000 miles and extensively towed a 4,000 lb trailer with it. I had no additional oil or tranny cooler and never had a problem, save with the brakes.
3rd gen 'Runner brakes are marginal for just stopping the truck. If you're going to be towing anything over 1,000 lbs, make sure your trailer has brakes and they work. If it has electric brakes, you'll need to buy and wire up a brake controller. Surge brakes don't need a controller and can work well.
I added rear Air Lift bags to my '98 shortly after I got it. They were cheap, easy to install and did a great job of levelling the rig. I'd highly recommend them.
My '98 did a good job with my trailer and I still miss it. Good luck with yours.
Old Apr 25, 2006 | 08:18 PM
KyleT's Avatar
i have seen plenty of 3rd gens with no rear hitch.
valley and hidden hitch carry quality hitches as well, or even a factory one that someome else took off and is selling.
Old Apr 25, 2006 | 08:43 PM
hupptoy's Avatar
Hitches were definitely NOT standard on 3rd gen runners.
And, I would avoid Valley hitches, unless you like rust within 3 months...(I put a Valley on my 93 pickup and it rusted within 3 months. Valley told me rust wasn't covered under warranty!!)
hupptoy
Old Apr 25, 2006 | 09:00 PM
bigacuralvr's Avatar
Curt hitches are pretty sweet, plus they have the tube style that doesn't sit near as low as the box style. Mine didn't come with one standard, and it's a 99 Limited. It was deff an option for some.
Brett
Old Apr 26, 2006 | 05:48 AM
chadbobb's Avatar
alright, well i pretty much only going to be towing a lightweight trailer with a quad on it. So that is under 1000 pounds.
Anyone know of a website i can order a hitch from?
Old Apr 26, 2006 | 06:25 AM
MTL_4runner's Avatar
Not true....they are not standard but can be added from various sources (dealer, reese, U-haul, etc). Just make sure it is a class III hitch or better and has a 2" reciever.
While it can be done, towing large loads with no tranny cooler is definately not recommended and will certainly cause increased wear due to additional heat generated during towing. Get one!
I do agree.....the 4runner brakes are not made to tow and you should have some sort of brakes on the trailer if you exceed one ton of towing weight. If you tow alot you might also consider doing the Tundra brake upgrade:
https://www.yotatech.com/forums/f2/big-tundra-brakes-3rd-gen-4runner-74601/
For stock 4runners, airbags are definately the best way to level out the increased tongue weight carried in the rear. Other suspensions/lift springs can be added to help with this as well.
Comments in red above.....
Old Apr 30, 2006 | 06:51 AM
hard-knox's Avatar
Toyota made it easy to add the wiring harness. Just pick one up at your dealer. One end has the standard 4 pole connector. The other end plugs into a harness just under the driver'd side of the rear bumper. There is a picture of it in your owners manual if you have trouble finding it.
Old Apr 30, 2006 | 08:34 AM
hupptoy's Avatar
The wiring harness is easy, but not quite as easy as hard-knox said (unless they changed something after 99...).
Most wiring harnesses do plug in, but usually behind each taillight and then to a converter and then out a hole to the rear bumper.
hupptoy
Old Apr 30, 2006 | 09:28 AM
914runner's Avatar
I would go to your local wrecking yard to find a hitch. You can find stock hitches for pretty darn cheap, along with the plug harness.
Old Apr 30, 2006 | 10:59 AM
chadbobb's Avatar
well... looks like a lucked out. The 4runner i got has the hitch, i just need the ball.... the (receiver i think is what it is called) is there.
Thanks for all the help.... If i tow any heavy loads i will have to look into a transmition cooler
Old Apr 30, 2006 | 08:14 PM
Macgyver's Avatar
I have a OEM hitch and harness for a 3rd gen, if someone is interested.
Old Apr 30, 2006 | 08:23 PM
CLin9383's Avatar
I have a 96 with a factory tow hitch. I was wondering if the newer ones like the 2000s and higher are lighter and more hidden. My hitch is rusting also, does anyone know if the new ones will fit or slight modifications? I would like an OEM 2000 or higher if possible. Thanks!
Old May 1, 2006 | 05:03 AM
hupptoy's Avatar
They should fit, but I doubt that they would be lighter or more hidden, although they will probably have less rust...
Your best bet would be to sand and paint your existing hitch or buy one of the round tube hitches as they are a little less visible.
hupptoy
Old May 1, 2006 | 05:13 AM
The hitches won't be much different from what you currently have except maybe less rust. Just take your hitch to someone and have it sand blasted and then shoot it with about 5-6 coats of semi gloss black rust paint. I did the same thing to mine after it rusted a bit and now it looks like new. Very easy and cheap.
XtraCab
Apr 12, 2020 05:25 AM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
