426 Hemi Powered Yoda
SBC 400 = siamese cylinders (no coolant flow between each cylinder)
SBC 350 = full coolant flow around cylinders (better cooling)
SBC 383 = more torque than 350, better cooling than 400
ah, wasn't aware of the siamesed bores, now that makes sense...my work truck has a 383 in it with an SM465 4 speed. good stump pulling power, it's routinely used to haul excavators and tractors when our 2 ton truck is out.
it's very, very cold blooded though...i think some aluminum heads would've been a great investment.
Hemi-Powered FJ40 in Montreal
Hi guys and gals,
Just so you know, a local guy named Ken Peets had a Blue FJ40, as a winter car, with a 426 Hemi in it. His summer cars included Boss 429 Mustang and other Hemi car. He had to cut the firewall and move it back 4 inches to make it fit. He was our local hot rod guru when I was young, and he died about 20 years ago. His truck is still around somewhere, and it used to roam our streets back in the day. He built it at Todco Racing, just ask Yogi.
Dangerous Dan
1992 Dodge W350
1986 Ford Ranger Turbo Diesel
1963 Oldsmobile Super 88
Dangerous Dan
1992 Dodge W350
#25
Meanwhile the Mopar LA engines seem to be the kicked puppy of the litter. The 318 is nigh indestructable, the 340 is a legendary screamer, and the 360 shines best when grunt is needed...all three have excellent Tq charisteristics for their respective displacement, owing largely to their 6.123" long connecting rods. (by comparison, the 'trick' rods for chevy are 6" even)
#26
My bro just had his 68 426 rebuilt and it is fairly tame but it has 800 hp you may want to sell your mother in law as well for some one tons and a beefed up 727 torque flight just to take the power available.
#27
Hi guys and gals,
Dangerous Dan
1992 Dodge W350
Dangerous Dan
1992 Dodge W350
#28
i vote for a cummins/cat straight six diesel--they are industructable--you could probably idle down the free way at 80mph with low enough gears......you would be like that gasser motor car built around either a P-51 engine or large tank diesel??
You probably wouldnt even need a radiator because you wouldnt be working it.....
sounds like a monster garage build...
Not related to here--but i plan on throwing a Lexus V-8 in my Series 1 XJ6 when i get done with the Yota
delmert
Sep 30, 2015 04:34 PM
