4 Runner Tacho wiring diagram
Old May 29, 2004 | 06:36 AM
natalshark's Avatar
Can anybody help me with the colour coding for the tacho wiring onto the injector pump i.e. what colour wires from the loom connect onto the two blue wires on the diesel injector pump (2L-TII). The idiotic owner before me cut the wiring loom.....
Old May 29, 2004 | 07:42 AM
Breezey's Avatar
Guest
2nd gen 4Runner?
Old May 29, 2004 | 07:44 AM
Breezey's Avatar
Guest
Here , I hope this helps
Toyota
4-Runner
1994-1995
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Start:
BLACK
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/RED
Ignition #2:
BLACK/YELLOW
Ignition #3:
Accessory:
BLUE/RED
Brake Light:
GREEN/WHITE
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT IGNITER OR DIAGNOSTIC PLUG *
Parking Lights:
GREEN
(+) AT WHITE 8 PIN CONNECTOR@FUSEBOX
Headlights:
RED/WHITE
(-) AT HEADLIGHT SWITCH *
OEM Alarm Disarm:
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Igniter Located On Driver Firewall, Diagnostic Plug Located On Passenger Side Of Engine Compartment On Fuse/Relay Box. BLACK Tach Wire Also Found At Pin #20 In A White 20 Pin Connector In Passenger Kick Panel.
Old Jun 4, 2004 | 06:13 AM
Astralplane's Avatar
Breezy, I just installed a keyless entry system (Valet) and have a question for you.
Will the parking lights only blink if I add a relay?
I didn't realize it was a positive connection unitil it didn't work.
Old Jun 4, 2004 | 11:31 AM
Breezey's Avatar
Guest
most of the time the alarm will have the relay built in, if not you do need to add one . The parking light wire is right below the fuse box on the drivers side, very easy to get too.
Old Jun 12, 2004 | 03:34 PM
natalshark's Avatar
Thanks
Thanks Greg A,
My 4Runner is 1st Generation Japan version, 2L2-T motor..
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
91toybeater
Dec 27, 2015 07:46 PM
TheManOutside
Jun 18, 2015 03:32 PM
Dennis140
Jun 17, 2015 10:37 AM
