4 inch suspension lift?
Old Nov 4, 2002 | 05:17 PM
BigJohn's Avatar
this guy says he has a 4inch lift is it 2wd?http://www.buysell.com/bestoffer/vie...sp?id=20662109
Old Nov 4, 2002 | 06:18 PM
TuffToy's Avatar
I think it is a 4wd, I don't think Pro Comp makes a Suspension lift for that style 4runner in a 2wd. It also sets up higher and allows for more clearance, it is able to run 33" tires and I think the 2wd with 4" suspension can run 31" tires. Not to sure though but it looks pretty nice. Don't see many new body style 4runners lifted
Old Nov 4, 2002 | 07:04 PM
Adam F's Avatar
That rig does in fact have a Pro-Comp 4" suspension lift. It has been fitted to that rig using the kit for the Tacomas. You can tell it has it by the little silver image you see in the wheel wells. That is a upper ball joint spacer provided in the PC lift kit. Also you can see the aftermarket skid plate, which I'm also assuming is part of the PC kit.
Old Nov 5, 2002 | 05:47 AM
Ace Laserna's Avatar
Ditto to Adam's post. He's probably running a Tacoma Procomp 4" susp. lift on the front with coils + spacer on the rear.
Ace
Old Nov 5, 2002 | 06:04 AM
Stump1883's Avatar
I'm a 3rd Gen 2WD and lifted, 2.5", I can easily run 33's with correct backspacing. I'm running 32's with the stock wheels right now, new AR wheels and I will fit 33s for my next set. So you don't really need 4" to clear 33's. But I do agree that it is a PC lift for Taco's just modified a bit.
Old Nov 5, 2002 | 06:10 AM
data's Avatar
Senior Member
why don't many 3rd gen 4runner folks retrofit this procomp lift for their 4runners? is there something i'm missing here?? that is the first one i've even seen like that......I like it
Old Nov 5, 2002 | 09:25 AM
Adam F's Avatar
Cause the front end alone is $1000. That doesnt include shocks or springs. Just some fancy brackets to lower the diff and a upper ball joint spacer. Then you have to get some custom rear springs or spacer, which might be $300-$500. So thats $1300. Your stuck with your stock springs and shocks. Go buy new springs and shocks, thats like $250 more. Your at $1550. Add professional installation if you cant do it yourself--$600? Your up to $2150. So for over $2000, you basically now have room to fully stuff 285's. OR....
You can just do a basic 2.5-3 inch suspension lift, and a 1" body lift. Much cheaper and easier.
Old Nov 5, 2002 | 09:30 AM
Stump1883's Avatar
Exactly Adam F, next on my line up is that 1" body lift. Much cheaper than that PC lift kit, and without having to do all that retro-fitting as well.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
94ofCanada
Aug 14, 2015 06:37 AM
bobpat
Aug 1, 2015 09:25 PM
Vargntucson
Jul 4, 2015 12:15 PM
