3vze Adjusting Idle -- Help Please
Old Jan 27, 2005 | 06:57 PM
Morphine's Avatar
Oh gurus and members smarter than I (that means most everyone here), I want to adjust the idle on my 91 v6 3vze 4x4, as it seems to be idling extremely low and rough. I read up on the process and using the "Idle adjusting screw", however how much does one turn this screw? I turned mine 1/2 turn in each direction and it made no apparent change.
Should this screw be sensitive or am I overly cautious in my adjustments? Any help, advice, links, pictures, stories will be greatly appreciated.
While waiting or tomorrow I plan on testing the TPS, but until then...
Thanks
-=Morphine=-
Old Jan 27, 2005 | 09:04 PM
SolidDigital's Avatar
You just aren't turning it enough. I made a couple turns to mine before I got it where I wanted it.
Old Jan 28, 2005 | 05:27 AM
AgRunner06's Avatar
Get the vehicle nice and warm before you start adjusting the idle. Yes, it may take a couple turns. Just turn it 1/2 a turn or a full turn then rev the engine up and let it fall back down to the idle speed. Do this until you are satisfied.
:bounce2:
Old Jan 28, 2005 | 07:58 AM
Marc's Avatar
Turning it out increases idle, in decreases.
Old Jan 28, 2005 | 09:53 AM
Morphine's Avatar
Thanks for the input. I let the engine warm up before I tried testing it last time. however i didn't rev the engine and let it fall back down. The label in the engine compartment says the idle should be set to 850rpm's. This sounds low as my other yota's were set at 1050. Should I follow the factory label or go by my gut feeling in what sounds and performs best? Also what are the consequences of settingthe idle to high or leaving it to low?
-=Morphine=-
Old Jan 28, 2005 | 02:05 PM
I keep mine at around 800, my neighbors 3.0 is around that too.
Old Jan 28, 2005 | 04:04 PM
gwhayduke's Avatar
Take the hose off that leads from your valve cover at the intake tube and spray a lot of throttle body cleaner in the hose while the engine is idling. The engine will pull the spray through the idle air bypass tube and you'll clean out the idle bypass. Then most likely, you'll notice your 4Runner idling faster than it should. Just adjust the idle screw and you're all set.
Old Jan 28, 2005 | 05:17 PM
only problem I've heard of with doin that is that could mess up your TPS. as it's sensitive to tb cleaner if it were to get in it.
Old Jan 28, 2005 | 05:38 PM
gwhayduke's Avatar
Which is why you use TB cleaner, not carb cleaner.
Old Jan 28, 2005 | 06:07 PM
didn't realize they made one that's safe for electrical parts,.
Old Jan 28, 2005 | 06:34 PM
gwhayduke's Avatar
Neither did I til Gadget put me onto it.
Old May 7, 2011 | 03:17 PM
pholife's Avatar
dumb question, where is this screw to adjust idle located at? thank you
Old May 7, 2011 | 03:38 PM
MudHippy's Avatar
No, what's dumb is that somebody asked this question about his 91 in the 95.5-2004 Tacomas & 96-2002 4Runners forum.
Blamalam
Mar 12, 2022 07:34 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Sidherish
Aug 2, 2015 01:42 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
