3rd Generation front end rebuild kits
Old Jan 14, 2014 | 04:38 PM
PuroPinchePedo's Avatar
If was looking for a front end rebuild kit for my 1997 4Runner Limited. I saw a few post and no one could find one and was just buying the pieces individually. I came across this on ebay at a good price. What do you guys think?
Attached Thumbnails 3rd Generation front end rebuild kits-kgrhqvhjfie-g-r-ibqi-kvgpq-60_57.jpg
Old Jan 16, 2014 | 08:36 AM
hilgeg's Avatar
Is that an eBay kit? If it is - don't do it. Especially the lower ball joints. I bought a similar kit and had lower ball joint failure less than 10K later. OEM lower ball joints only.
When I re-did the lower ball joints I found the kits tie rod ends were showing signs of wear already too (very loose). Save yourself some time and frustration and do as much OEM as possible. Otherwise I've had good luck with NAPA brand stuff (all but LBJ's).
Pretty sure Texas_Ace had the same problem with the kit too.
Old Jan 16, 2014 | 08:57 AM
Jomoka's Avatar
+ 1 on the LBJ thing. Google around, there have been more than a few premature failures of aftermarket balljoints. And the failure mode (the ball popping out of the socket) precludes any possible sort of installation error.
An LBJ failure is pretty catastrophic unless you're lucky enough to be going very slowly.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
