3rd Gen roll bar install
I just picked up a 1st gen roll bar off ebay for dirt cheap! I've done some searching on how to install on my 3rd gen, but the posts I read weren't really clear. I was wondering what exactly needs to be done to get it to fit, I've heard that the front legs need to be cut, but I don't know how much. Other than that, I should just have to drill the holes in the cargo area and it should bolt right in, correct?
https://www.yotatech.com/forums/show...H8796+roll+bar
Here is a link to my thread. Cut the front legs down 2" weld some mounts back on and then slide in through back seats and drill your holes and bolt it down.
This thread will give you more than enough info.
I've since taken mine since to work on my cargo area and was able to take it out and put it back in by myself. Just take your time doing it.
Here's my install if needed: Roll Bar Install
Please do not assume you need to cut 2" off the rollbar...measure for yourself several times and then cut less than you think and test fit it. MUCH easier to cut off more later than try to add some back.
You also might want to consider an angle for the bottom of the legs to match the contour of the wheel wells.
Good luck!!
Make sure you take some pics!!
I picked up a 1st gen rollbar also, and I am going to put it in my Taco, havent yet decided if i am going to do it way back in the bed, like where it came out of on the 1st gens, or right behind the cab, or maybe even IN the cab, I just dont know...
Heres another one for $75.... http://denver.craigslist.org/pts/343242728.html
Try offering him $50~
WTB[PacSoWest]: Looking for Smittybilt front bumper
shisha1999
Mar 16, 2016 12:25 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
