3rd gen Fog lights??
Old Apr 22, 2004 | 05:38 AM
oldguy's Avatar
I have a '97 4-Runner that had the fog light option but the lights were removed. The switch and wiring is still there. I think the orig lights were 55 watts. I would like to put some driving lights in the same mounting spot and use the orig wiring. Anyone know if I can put 100 watt lights on the orig wires and relay?
Old Apr 22, 2004 | 06:24 AM
lee's Avatar
lee
97 ones were the square hellas right?
Old Apr 22, 2004 | 06:38 AM
waskillywabbit's Avatar
Talking OEM fog lights
My 00 SR5 has all the wiring in place but no switch. I investigated this option a while back, but with an ARB now, there is no need. If you already have the wiring and switch I would imagine you can hook up any fog lights. If yours are the ones that go in the lower valance then you can get the Hellas that fit there or PIAA offers some options that will fit. Try a search for OEM fog lights or something similar.
Old Apr 22, 2004 | 06:39 AM
SLC Punk's Avatar
yep
Old Apr 22, 2004 | 08:55 AM
oldguy's Avatar
I did a search and got a bunch of info but am wondering how much wattage I can run with the orig wiring?
Yes they are the rectangle ones.
Old Dec 16, 2005 | 05:49 AM
mjwalfredo's Avatar
Did anyone ever answer the question about using 100watt bulbs with the factory wiring?
Old Dec 16, 2005 | 06:24 AM
X-AWDriver's Avatar
100 watt bulbs could be a problem for the stock harness.
Old Dec 17, 2005 | 05:42 AM
dirtypuke's Avatar
my 98 4r sr5 came with the brush guard and the square hella fog lamps. i hope to buy some big round lights and mount them on the top bar on my brush guard.
Old Dec 17, 2005 | 02:42 PM
wilsonator's Avatar
I've got the exact same fog light setup as the above picture but one of my lights is busted. I'm having a difficult time tracking down a spare. Can anyone shed some light. No pun intended...
Old Dec 29, 2005 | 03:54 PM
Mbretl's Avatar
I have a 98 runner. The relay is on the drivers side fender. You may want to move the battery out to get to it easier. Lights and wiring harness can be purchased at Rallylights.com . The lights are pt# HL65060 and interchangable @ $60 each. Their contact info is below is taken from a recent order I made. They should be able to give you any part you need.
If there are any questions, give us a call at 610-944-3233, 10:00am to
5:00pm Eastern Time, Monday through Friday. Outside those times, leave a
message and we'll get back to you when we can. You may also email us at
mail.mosports@verizon.net -
Good Luck -
Old Jan 3, 2006 | 11:09 AM
Andrey's Avatar
You need to use 55 Watts. If you'll use 100W, you'll melt the wires.
-- Andrey
Old Jan 3, 2006 | 12:06 PM
bflooks's Avatar
performance products sells the hella kit for the early 3rd gens. a little pricey though. but! they are hella lamps, so you know they are good quality. come with wiring and brackets as well.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
