3rd gen 285 spare tire?
Old Dec 29, 2004 | 09:12 AM
Crux's Avatar
Are any modifications needed to mount the spare tire underneath the rear for a 285/75R/16 tire on a 3rd gen 4Runner?
Old Dec 29, 2004 | 09:29 AM
Bratik's Avatar
I didn't have to do anything, except may be letting most of the air out and airing up after it's in place.
Old Dec 29, 2004 | 09:31 AM
lee's Avatar
lee
i have a similar Q... if i have 285/70/16 tires, can use a 265/70/16 spare? or is that ridiculous?
what if i have 265/75/16 tires and a 265/70/16 spare
Old Dec 29, 2004 | 09:38 AM
FilthyRich's Avatar
as a spare the difference is negligable(sp). it will get you off a trail or an interstate. it would be one thing if oyu had 35s and a 31" spare. IMO
Old Dec 29, 2004 | 10:20 AM
Darren's Avatar
You can run one with no problem if you don't have a hitch receiver mounted.
If you do want a hitch receiver, the only one that I know of that works is the Hidden Hitch Class III, square tube style. It is part # 87511, which can be found on this page. OEM receivers will not work.
Old Dec 29, 2004 | 02:05 PM
Sherpa's Avatar
Yep. The factory hitch won't clear a tire that large.
Running different diameter tires is never a good idea, especially for long distances. One problem is it can prematurely wear out a limited slip differential, with one wheel constantly turning faster than the other.
To get you off the trail and back home, heck yeah, you should be fine.
-S
Old Dec 29, 2004 | 07:15 PM
Dozer's Avatar
Mine did not fit with the hitch until i got the 1.5" body lift. It fits fine now...It doesn't matter though, 'cause my Sonoran Steel rear bumper comes TOMORROW!
On the 265 spare with 285's...wouldn't that cause chaos with your traction control? Mine goes off if one of my tires has very low pressure...
Dozer
Old Dec 29, 2004 | 09:43 PM
HOJU's Avatar
when i went to 35's, i put a 285 under there for my spare, but i had to cut off my custon hitch to do it.... (super tight fit with the 265) but that didn't bother me too much, my new bumper has a hitch built in-
Old Dec 30, 2004 | 06:22 AM
Jonathan's Avatar
If you air down a 285 to about 12 PSI it will fit with a factory hitch, you just have to make sure when raising it into position, that you don't let it rest agains the panhard bar. This is how I have mine mounted.
Old Dec 30, 2004 | 06:33 AM
Bratik's Avatar
-S
Mine feets just fine. Been there for more than 1 year.
Jun 1, 2021 01:51 PM
94whiterunner
9
Sep 22, 2015 07:28 PM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
