3rd Brake Light - No Worky...
Old Dec 20, 2008 | 04:03 PM
BushPig's Avatar
Just put a brand new bulb in my 3rd brake light ('99 4Runner).
No worky.
Does this happen a lot to 3rd Gen's?
Any tips?
Old Dec 20, 2008 | 04:20 PM
Ironmike4x4's Avatar
Do you know how to use a test lamp? If so then test the green-white wire for power. If you have power then the problem is on the ground side. If no power then I'd be sure I had brake lamps on both the left and right side. If you do have lights then you have an open wire from the junction connector to the bulb. If no brake lamps at all then check for a blown 10Amp stop fuse.
Old Dec 20, 2008 | 04:23 PM
BushPig's Avatar
I have a Multimeter that I was given, but I don't know how to use it
Both L + R rear brake lights / blinkers / tails work fine, that much is certain.
It would appear then that I have an open wire from the junction connector to the bulb, right?
How do I locate it?
Thank you for the help!
Old Dec 20, 2008 | 04:33 PM
Well that's what it sounds to me like. I'd make a quick run to Wal-Mart and get a $4 test light. A meter is really good for heavy diagnostics but for a simple test it's really too much. With a meter check for voltage at the green/white wire and ground. You should be getting 12volts. If not then either you still have a bad bulb or a bad ground. If no voltage is present yes an open from the junction connector. Alldata is not throwing me a bone as to where the J14 junction connector is so I'm hoping someone else here will chime in.
Old Dec 20, 2008 | 04:45 PM
Here's a diagram for you if it helps. I don't know how skilled you are with electricals but here is a diagram. [IMG][/IMG]
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
fountain
Dec 31, 2015 06:08 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
