3.4l v6 tacoma, what will it sound like straight piped?
Old Apr 11, 2009 | 04:42 PM
TMZ's Avatar
TMZ
We are talking about a 3.4 not a 3.0. BIG difference in EFI.
Old Apr 11, 2009 | 05:15 PM
Dublin's Avatar
So a newer EFI system is not able to regulate and adapt as well as an older system??!!
Old Apr 11, 2009 | 06:15 PM
ARB1977's Avatar
I took the cat back off mine to paint it black. In the process of painting it black i had to move my truck....lets just say it wasnt really that bad without the muffler.
Old Apr 11, 2009 | 06:50 PM
Red3.slow's Avatar
performance issues aside, it sounds horrible. My old 95 had just a 12 inch glass pack on it, after about 6 months I got so tired of it. I've heard 3.0's and 3.4's with straights all I have to say is for the love of god please do not put straights on your tacoma,
I would say just about the time you get in to college and get broke as can be, broke to the point your eating mustard sandwiches your going to get sick of it, but you wont be able to fix it and you'll have to live with it, and soon you'll come to despise driving your truck. So for the love of god save the relationship with your truck and leave the exhaust some what intact
Old Apr 11, 2009 | 07:57 PM
  #25
SnowRunner98's Avatar
i heard one, it was ridiculous loud! all the way out the back and duals. I'm in college, I have never ate mustard sandwiches.. but I sure ate a bunch of top ramen! lol. serious, get a glasspack, 18' and get some clamps from the parts store. do it all in the parking lot for about 50bucks. donate plasma! lol. (It's not illegal here) just a VIN and proof of insurance and plates! cracked windshield, broken tail lights with tape, and as long as you have two headlights at night!
Old Apr 12, 2009 | 08:27 AM
  #26
Belize Off Road Team's Avatar
Has anyone here even tried it? i have been running a straight pipe on my 3.0L for well over a year now. i can tell you that adding a small resonator reduces the noise but not effect the massive performance/economy that I gained by removing the CAT & muffler, when i finally finish the 3.4L swap I'm just running off of the Downey ceramic headers and nothing more.
Old Nov 20, 2012 | 10:05 AM
  #27
Super old thread but interesting read. I'm about 2 weeks out from finishing up the build on the truck and it will be running just doug thorley headers to a magnaflow muffler. No cats at all. Part of me wonders how it would be with just a glass pack dumping behind the cab though. I don't want to go true straight piped as I don't want it insanely loud but I want it to flow as best as possible. Any thoughts?
Old Nov 20, 2012 | 12:21 PM
  #28
donomite49's Avatar
listen to mine( link in sig).
Old Nov 20, 2012 | 02:56 PM
  #29
Chickenman's Avatar
"I have always felt that the best money spent is in the exhaust system if performance/economy is the goal. The engine works best for all around with a little back-pressure at the port, once past that point the goal is to get the gasses out of there, nothing else can be gained." From http://www.4x4wire.com/forums/showfl...0&fpart=2&vc=1. Posted by Engnbldr.
Old Nov 24, 2012 | 05:16 AM
  #30
Pat8942's Avatar
Backpressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Engines need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Engines need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s). (Taken From Another Site But I Don't Remember The Name)
Old Jan 1, 2013 | 07:08 PM
  #31
zipposrule's Avatar
drop a 5.0 or a 7.3 stroker in it and then well talk about straight pipes. until then no
nvwiggins
13
Jun 16, 2016 03:05 PM
LCE_Performance
Oct 1, 2015 01:03 PM
treadonmenot
3.4 Swaps
Aug 22, 2015 12:40 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
lbb-1
Dec 16, 2003 07:14 AM
