3.4L Oil Capacity Differences?
Old Feb 8, 2011 | 12:36 PM
etc.'s Avatar
Originally Posted by BajaRunner
Here's a pic of my dipstick. It measures 19" long (to the end of the yellow handle). I don't see any Asin or Toyota markings. In fact, I dont see any markings on it.
The oil is not going anywhere. I put in 6.25 to 6.5 quarts and it stays at the full mark. I did realize that after doing the oil change I do have a leaking valve cover, and burning oil smell (going onto exhaust manifold) making me think the dipstick is wrong. I believe I will just continue to use 5.5 quarts from now on.
mine measured the same.
Old Feb 8, 2011 | 02:10 PM
J2F42C's Avatar
Baja,
Replace the valve cover (hopefully it is the passenger side), then change the oil with 5.5 qts and I'd be willing to bet it would read correctly.
I had a bad leak at the cam plug passenger' side, and until I changed it last year with the valve cover, I probably lost 1/2qt every six months (I change my oil once a year at around 5000 miles). Now, I have not had to add one ounce in seven months.
Good luck....
Old Feb 8, 2011 | 04:32 PM
quicksilvr's Avatar
Originally Posted by aowRS
I've done more than seventy (yes, 70) oil changes on my 4Runner since purchasing it new in '01.
5.5 qts with a factory oil filter each time.
Andreas
You were't messing around with the 3000 mile interval were ya!
I do not think it could actually take more than 6 quarts to fill the 5vz-fe. Something in the "weights and measures" category is messed up if it does, lol.
Personally, I just put 6 in my rig all the time because it's easier than 5.5. It shows maybe 1/16th of an inch over full when I put in 6.
My dipstick measures 19" as well.
Old Feb 8, 2011 | 04:43 PM
skjos's Avatar
Just to add more data, my stats:
2002 with a 90915-YZZD3 filter = 6qts (right at the top mark on dipstick)
Old Feb 8, 2011 | 06:02 PM
  #25
etc.'s Avatar
Is that the larger filter?
Old Feb 8, 2011 | 07:17 PM
  #26
PismoJoe's Avatar
See above post to answer that.
Baja, if its a toyota dipstick, it will have a P/N etched into it. Looks like XXXXX-XXXXX (10 digits total)
taller1
Jul 16, 2015 03:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
msane99
Jul 11, 2015 08:08 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Nickdigg
Jul 7, 2015 06:04 AM
