3/4 ontop 3"
Old Mar 1, 2009 | 12:34 PM
darbtaco11's Avatar
3/4 ontop 3"
hi i have a 2wd 99 tacoma with a 3" skyjacker lift. is it possible to still fit a 3/4 of an inch coil spacer on or no?
Old Mar 1, 2009 | 01:03 PM
Gerdo's Avatar
Is the 3" lift a bracket lift?
Old Mar 1, 2009 | 01:04 PM
darbtaco11's Avatar
yes
yes it is wow sombody who finally knows what it is but yes it is
Old Mar 1, 2009 | 02:19 PM
darbtaco11's Avatar
3/4 ontop 3"
Old Mar 1, 2009 | 03:35 PM
waskillywabbit's Avatar
Please do not double post threads and this has been moved to the proper tech forum.
Thanks!
Old Mar 1, 2009 | 06:16 PM
Gerdo's Avatar
Do you have any pictures of the setup and the angle of your CVs? If they are at a severe angle then no I would not add a spacer. If they are fairly level then you might be able to add the spacer.
Probably the best answer you are going to get is "sure give it a try and see if it works".
Old Mar 1, 2009 | 06:27 PM
trd_4runnin11's Avatar
It's a 2wd. No CV angles to worry about. So yeah, you should have no problems with the spacer.
Old Mar 2, 2009 | 10:12 AM
Gerdo's Avatar
I missed that. It is 2wd. I would agree, probably no problem adding the spacer.
Old Mar 2, 2009 | 01:06 PM
darbtaco11's Avatar
ok thanks yall i will tell what happens when i puti it on
JUICE222
Oct 13, 2015 08:50 AM
old87yota
Sep 9, 2015 12:39 PM
Kreedy1
Sep 8, 2015 06:33 PM
sniper34639
Aug 31, 2015 07:56 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
