View Poll Results: Would you buy an engine swap kit?
Hell YES, i have a NEED FOR SPEED
32
24.43%
YES, but i gotta save the money up 1st
33
25.19%
Possibly, depends on the price
44
33.59%
doubful, im poor or not good at mods
11
8.40%
HELL NO, im keepin my 3.0
11
8.40%
Voters: 131. You may not vote on this poll
2nd Gens, who wants an engine swap?
Old Feb 26, 2004 | 09:05 AM
  #121
Faded's Avatar
Originally Posted by Bumpin' Yota
Seriously though, any updates?
I feel ya, interested to hear some news, good or bad!
Old Oct 18, 2004 | 10:56 PM
  #122
n8james's Avatar
I have done the 7mgte swap in my 93 toy xcab.
[img] http://www.supracharged.com/other_trucks/nate/grey1.jpg [/img]
The 2jz-ge swap IMO is only worth it if you are going to make it a turbo.
You can throw a turbo on the 2jz-ge pretty easily using the stock 2jzge ECU if you only boost around 5-7 p.s.i. Anything more and you'll need to upgrade your ECU system. I would use the 2wd mkIV supra TT auto tranny. They are stronger and have more clutch packs inside. They can easily withstand 400+
RWHP. Now with big tires it would be less but could still handle 350+ RWHP.
I have been running over 250 RWHP on my 93 a340H auto tranny for over 2 years with no problems( with 35" mtr's). For the 2wd tt auto tranny you would run a divorced T-case using OTT's adapter. THen you can use the desirable gear driven toy t-case instead of the POS hydraulic a340h t-case.
There is no difference in doing a 7mgte or 2jzte swap if you know what you are doing. I have done both. Both motors are abou the same size and fit respectively the same way in the engine bay. There are a few differences with the oilpans but nothing big. If you are going to do the swap RIGHT you will in both cases be making you're own motor mounts so the swaps are abouy equal, labor wise. If you do the swap trying to use the stock 4 clylinder
Motor mounts, the motor is not in the IDEAL position. It works but you can position it better, further back and lower in the bay making your own motor mounts. If you do it right it'll take less than 2hrs to do the mounts. Sorry i can go on forever. there are so many possibilities. Just my 2 schillings
Old Oct 19, 2004 | 05:17 AM
  #123
SuperRunner's Avatar
well, the 2ZJ is about 2 inches longer. And I don't know about the 22R mounts. Never tried it....Yet. I will still make custom mounts. It takes me a couple hours to fab up some engine mounts anyway. Then I get custom placement.
2JZ swap is a much better swap for horsepower, but I believe the 7M may be better for some low end torque, because the 7M has a much longer stroke. Hmm, Iill have to go look at some stock torque curves.
Old Mar 14, 2005 | 12:23 PM
  #124
cimahar's Avatar
I'm interested in the 2jzge swap, and I have a Second Gen 1995 4Runner . I think that the turbo would create to many troubles, where do you stick the intercooler ? not alot of xtra space under the hood with an inline six packed in there.
Old Mar 14, 2005 | 12:48 PM
  #125
you can mounted in inside your bumper, on top of the engine, you can side mount it behind your head light. Those are the most common.
Old Mar 14, 2005 | 02:50 PM
  #126
NCSU-4runner's Avatar
wow, this thread up from the dead again. just a FYI, i was pretty clueless when i got the idea for this thread.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
DjShiznit
Jul 5, 2015 11:51 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
infinityisfive
Jun 16, 2015 06:51 PM
