2nd gen spacers...
Old Nov 4, 2003 | 06:22 PM
blackrunner91's Avatar
2nd gen spacers...
Hey, does anyone know where I can find some 1.5-2" spacers for my '91 4runner. I installed the 4-5" Superlift kit on it a couple weeks ago and still have a little sag in the rear. Instead of lowering the t-bars, i'd rather just raise the rear some more to level it out. Any cheap tricks for the rear??? Thanks
,Louis
Old Nov 4, 2003 | 06:51 PM
CTB's Avatar
CTB
Cornfed? Daystar? Revtek? Try a search and see what you can come up with.
Old Nov 5, 2003 | 12:30 AM
WSU4runner's Avatar
I've got some Downey ones, I may sell for the right price You can check the Downey site, I think they're 140 for two plus extended brake lines and maybe something else.
Old Nov 5, 2003 | 02:45 PM
TheTank's Avatar
how much lift do you think you need? I have the 3" spacers from All Pro that work perfect and I'm trying to get rid of them. I have the Pro Comp lift in front but Downey's in the back and I had to put these spacers in to level it out and they worked great but I decided to order some custom coils.
Old Nov 5, 2003 | 07:10 PM
TheTank's Avatar
Hey. I put a 4" Pro Comp lift on the front of my '91 4Runner jsut in June but I used All Pro's 3" coil spacer and Downey springs in the back. This worked great but I just wanted a full spring so I ended up having some made which turned out to be a little more expensive than I though so I'm getting rid of the spacers. I bought them for $150 for the set and they're practically brand new so I'd sell them for $125. If it raises it just barely too much (which I highly doubt they will with that lift on the front) just add a heavy toolbox or something to the back or crank the torsion bars a little to even it out. These should work out great for you. Hope you're interested.
Old Nov 5, 2003 | 07:28 PM
fooddude's Avatar
i didnt know you could buy suspension lifts for just the front.Where can you get them.
Old Nov 5, 2003 | 07:32 PM
TheTank's Avatar
Well when you buy a suspension lift like the bracket kits like my Pro Comp, they have to order a bunch of different parts and they have to enter a bunch of different part numbers to make it a kit. I just had them order the brackets and everything for the front lift because I didn't like the lifting and lowering brackets in the rear because I've heard they flex too much and tear brackets off of the axle housing so I put my own lift together from different companies for the back and it's worked out great.
Old Nov 5, 2003 | 07:36 PM
fooddude's Avatar
how much cheaper is it just to do the front.
Old Nov 5, 2003 | 07:40 PM
TheTank's Avatar
What do you mean just do the front? Like just order the front separately and then do whatever you want with the back?
Old Nov 5, 2003 | 07:41 PM
fooddude's Avatar
ya im just wondering how much it would be just to buy all the parts i need to lift the front ifs.l
Old Nov 5, 2003 | 07:42 PM
TheTank's Avatar
I think just the front kit came out to $592 but that's without shocks.
Old Nov 6, 2003 | 05:48 AM
I can get the Superlift 4-5" kits. Whole or just the front. It would be like $600.
kawazx636
Oct 6, 2021 03:03 PM
Badlander
Oct 10, 2015 08:05 PM
voiddweller
Oct 2, 2015 07:47 AM
charlie_fong
Sep 27, 2015 10:06 PM
Toys4parts
Sep 26, 2015 01:56 PM
