2nd Gen ADD Sensor Help ?
When putting the finishing touches on my front lift last night I noticed that the wire connecting the sensor on the front differential (I assume it is a sensor) wasn't connected and the other end of the wire coming from the wiring harness has the connector missing.
I'm not sure how these wires need to be connected:
- the 2 wires comming from the wiring harness are pink and green.
- the 2 wires going into the front differntial are green, one has a white stripe the other a yellow stripe.
Any wiring advice would be greatly apreciated.
Does any one know what this sensor does and if it needs to be conected for 4WD to engage? I hear a noise when shifting to 4WD but no light comes on.
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
The sensor only switches on the 4WD light, your front diff will still be connected without it. And the wiring shouldn't matter, it's a simple switch. One wire goes in and the other is out, when in 4WD the switch closes and turns the light on.
Originally Posted by 95_4X4Runner
As part of the ADD defeat mod, it says to trace those wires up, and just splice them together, and the 4wd light will work as normal.
Mine doesn't work right now since I pulled the ADD junk...
Originally Posted by 914runner
I pulled the ADD junk and mine works
Originally Posted by Cebby
Did you swap axle tubes, or just do the defeat mod in the 4x4wire tech? Did you tie the wires together like suggested above?
EDIT: no I did not tie the wires together.
Jun 1, 2021 01:51 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
Steezy96yota
Jul 6, 2015 10:00 AM
