285-75 R 16's on 16x7 rims?
Old Jul 27, 2007 | 09:40 AM
spencerhayden's Avatar
Just wondering if anyone could direct me to a post or give me some info on mounting 285-75 R 16's on the stock 16x7 rims my 97 runner came with. I was thinking the rims might be too narrow. Thanks
Old Jul 27, 2007 | 09:43 AM
Ringmaster's Avatar
I have 285/75/16 Goodyear MTR's on the stock wheels of the 99 4Runner.
No problem...
norcalsvx's Avatar
i've put on about 30 or so 285's on a stock toyot wheel you will be fine (i've run 12.50 on a 7" before)
Old Jul 27, 2007 | 10:47 AM
aviator31's Avatar
What about A-arm rubbing with a 285 on the 5 Star 16x7, that's what I'm rubbing into. No rubbing at normal flex, but it's really close to it.
Old Jul 27, 2007 | 10:51 AM
MillerPKA's Avatar
your a arm articulates with the tire if you have at least 1/2" in between a arm and tire you'll be fine. 1/4" wheel spacers can be added to the front for extra assurace
Old Jul 27, 2007 | 10:52 AM
Nate08's Avatar
Some have rubbing issues, and some don't. With 285/75/16 a 16x8 rim with 4.5" of backspacing appears to be magic.
Old Jul 27, 2007 | 02:07 PM
cackalak han's Avatar
You should look into picking up a set of FJ80 LC/LX rims
Old Jul 27, 2007 | 03:31 PM
toy_tek's Avatar
I have 285's on 16x7 stockers. Coincidentally, Discount Tire will not mount that size tire on that size rim due to legalities I presume.
Old Jul 27, 2007 | 05:29 PM
Fo-runna's Avatar
I've got my 285/75's on stock rims with no rubbing, close but none. I have to drop the tire pressure to around 28-30psi to get a good even foot print and prevent the middle of the tread from wearing faster than the edges. I don't mind running the lower pressure on the road because it helps to count-act the stiffness of the OME's.
Old Dec 15, 2007 | 07:29 PM
Nate08's Avatar
I know this is old, but I'm about to get 285's and was wondering the lowest I can air down before I really start taking risks..Thanks.
Old Dec 15, 2007 | 08:54 PM
toy_tek's Avatar
10 psi
Old Dec 16, 2007 | 04:34 AM
CTRJ's Avatar
I do 10 as well.
Old Dec 16, 2007 | 05:12 AM
Nate08's Avatar
Originally Posted by 111db
10 psi
On stock rims?
Old Dec 16, 2007 | 07:05 AM
toy_tek's Avatar
Affirmative.
Old Dec 16, 2007 | 08:08 AM
CTRJ's Avatar
Originally Posted by Nate08
On stock rims?
Yup. No problems at all.
Old Dec 17, 2007 | 04:16 AM
emptypockets's Avatar
I've never aired down to 10 psi on stock rims...too chicken lol. I have been down to 15 through. Here's an upper a arm clearance pic with my 285's on stock 16x7 5 star rims.
Old Jun 1, 2009 | 05:39 PM
TEPUI's Avatar
I've lowered down to 7psi on the 5 stars without a problem.
Old Jul 5, 2009 | 07:30 PM
Drgoodspd's Avatar
<~~~tire idiot.... 285/75 16's are WIDER than 265/75/r16's?......but a 285 will still fit on a STOCK 97 4runner rim?
Old Jul 6, 2009 | 09:49 PM
CTRJ's Avatar
Yes.
Old Jun 12, 2012 | 07:13 PM
Tony Le's Avatar
I have a '99 Limited with 881's w top out extended spacer and 891's. I want to continue running the 16x7 15mm offset 5star rims with my new set of 285/75/16 BF AT but having rubbing issues (so says the tire shop) so I just ordered 1.25" bolt on spacers to bring it to -17mm offset.
was that the right move or could I have gone w 1/4" spacers. I dont want any rubbing, I do do alot of highway driving. what are your thoughts? thanks.
Tony
1uzRunner
63
Nov 10, 2018 03:58 PM
Jamie4runner2000
Jun 20, 2016 09:13 AM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
AkitaDog
Sep 3, 2015 09:01 PM
