22RE starting problem
Old Sep 17, 2004 | 11:37 AM
NCSU's Avatar
I have two different problems with my 94 Pickup 22RE when I try to start it.
First, when the truck is warm, like if I drive to a store and go in for a few minutes, when I come back out and start the truck, it will actually start fine, but the truck will feel like it has no problem, like its constricted by something. If I cut the truck off and start it right back up, it will usually go away. I have NO CLUE on what would cause this.
Secondly, every few days when I go out and start the truck up, it will turn over fine, but when it starts up, the engine will idle a low and be shaky, like its not getting enough gas. If I rev the engine up, it gets better, but its still not right. The truck will drive fine though after that.
I do have one trouble code that may have something to do with that and its Code 71, EGR system. I replaced the EGR valve with a different used one, but the code continues to come back. Anyone know what usually causes code 71?
Old Sep 17, 2004 | 11:43 AM
the_supernerd's Avatar
If it is EGR related, maybe the EGR is stuck open by the vacuum source. If you have a repair manual, it should tell you how to check it. I think you attach a vacuum gauge to the EGR hose and rev the engine and see what it does. Some times it should have vacuum and other times it will not. Maybe try disconnecting and plugging the EGR vacuum line and see what it does.
Old Sep 17, 2004 | 12:48 PM
NCSU's Avatar
Also, where's the IAC valve on a 22RE? If so, is it easy to clean? I've seen a picture of one on a V6, but its definitely not the same on my 22RE
Old Sep 19, 2004 | 02:39 PM
NCSU's Avatar
Old Sep 20, 2004 | 01:57 PM
Here is some information on the idle air control valve for your year of truck:
http://www1.autozone.com/servlet/UiB...3d80161005.jsp
Crazychris1871
Jun 27, 2016 10:38 AM
jennygirl
Nov 17, 2015 11:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Sandman
Jul 23, 2015 08:15 PM
Old Red 94
Jun 16, 2015 08:32 PM
