22RE question
Old Jan 15, 2004 | 02:03 PM
tenfourtyeight's Avatar
22RE question
How tight are the shiny bolts on the top of a 22RE engine supposed to be?
The red-circled ones I can spin with my fingers, the yellow ones I cannot. Is this normal? How tight should they be?
Old Jan 15, 2004 | 02:10 PM
cubuff4runner's Avatar
It has been a long time since I had a 22RE, but I believe they are supposed to be something like 19 ft/lbs.
Old Jan 15, 2004 | 02:13 PM
How do I figure out how tight it is? Special tool that tells you the ft lbs?
Old Jan 15, 2004 | 02:24 PM
Torque Wrench. Everybody should have one of these if you plan on doing a decent amount of work to your vehicle. If you look in any repair manual every bolt will have a different torque. If you pay attention to these and use a torque wrench you should reduce bolts breaking, warping, and stripping. You can probably pic one up for $20 bucks.
Old Jan 15, 2004 | 03:38 PM
My99's Avatar
Not sure about 22RE's, but other valve cover's i've worked on (4 cyl) were more like 10 ft/lbs or even less... they strip easy.
Old Jan 15, 2004 | 03:46 PM
What do the bolts hold down? What ill effects could happen if they fell out or are loose?
I'll check out that torque wrench.
Gracias.
Old Jan 15, 2004 | 04:00 PM
It looks like those are the valve cover bolts. If they are not tight you will leak oil and maybe loose a little vacuum. It's no big deal though, tighten them to the specs and you should be good if it leaks put a little p-tex on the rubber seal, especially near the end half-moon gromets. You may be right My99 it could be 10ft/lbs, its been a while.
Old Jan 15, 2004 | 05:33 PM
Cool, thanks guys. I had noticed it leaking a little more oil the past week or so. Good to know My trucks not dying.
So I got a torque wrench, anybody know how many ft lbs they're supposed to be? How/ where to find out?
Old Jan 15, 2004 | 05:34 PM
Brendan's Avatar
my fsm for my 92 says 52 in-lbf for the 22re
Old Jan 15, 2004 | 05:40 PM
My99's Avatar
Users of this information, note INCH/lb not foot/lb on that measurement.
Old Jan 15, 2004 | 05:51 PM
Thanks guys, I'm on it.
Y'all kick ass.
Old Jan 15, 2004 | 10:24 PM
Duffdog's Avatar
you dont want them too tight---or to fall out, then oil could be spewing out the valve cover.
T
Old Jan 16, 2004 | 02:25 AM
toy283's Avatar
I just use a 12mm nut driver. Hard to overtorque it that way.
Old Jan 16, 2004 | 03:00 AM
EWAYota's Avatar
my chilton states that too. anyone know what the conversion rate is for in. lbs to ft. lbs. or is there even one?
Old Jan 16, 2004 | 07:29 AM
toy283's Avatar
divide in-lbs by 12.
12 in-lbs = 1 ft-lbs, exactly the same as 12 in = 1 ft.
So 52 in-lbs would be 4-1/3 ft-lbs.
Old Jan 16, 2004 | 07:31 AM
EWAYota's Avatar
good deal! its 830 and i've already learned something!
Old Jan 16, 2004 | 07:33 AM
toy283's Avatar
That's why we're here.
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
