22re low RPM problems
Old Jun 28, 2005 | 09:51 AM
E30M3Pilot's Avatar
ive searched the board and haveint really found what im looking for so its time to ask....anybody have misfiring problems with the 22re at low rpm when accelerating? mine will jump and studder a little till its starts to get some engine speed..makes for poor fuel economy cuz you have to hold the gears longer....only does it under load (revs fine with no problems) and after it warms up...right at start up till the time it gets to operating temp its ok....then goes bad...ive played with fuel grades and timming but donenst seem to do much...anybody experence this?
thanks for the help all
Kevin
Old Jun 28, 2005 | 10:29 AM
Yota4runner's Avatar
Try getting new plugs and wires? That happened to me not long ago and changing them fixed it.
Old Jun 28, 2005 | 10:47 AM
E30M3Pilot's Avatar
the plugs, wires, cap and rotor have less then 6k on them so i dont think thats the problem...ill check for anything loose or outta spec
Old Jun 28, 2005 | 11:10 AM
quik05's Avatar
try changing the fuel filter,same thing happened to my buddy, clogged fuel filter, but sounds like spark plugs to me.
Old Jun 28, 2005 | 11:15 AM
DavidA's Avatar
I had the same problem with a bad MAF on mine. Engine was running way too lean and the exhaust manifold got red hot.
Old Jun 29, 2005 | 01:19 AM
retardedspleen's Avatar
Defanitly sounds like clogged fuel filter. go ahead and change plugs/cap and wires and all that...but id put money on the fuel filter! Good luck! Post up again telling us what it was that fixed it!
Old Jun 30, 2012 | 04:17 PM
Cadin's Avatar
"Post up again telling us what it was that fixed it!"
Why does no-one ever write the resolution to their problem? I am having the same problem on a 22ret. Thank you all.
Old Jun 30, 2012 | 04:27 PM
Teuf's Avatar
Subscribed
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
