22re low compression #1 cylinder
Old Sep 14, 2004 | 04:32 AM
bigbear4's Avatar
I just replaced short block. If cam timing is off one link, can it cause this problem? Thanx
Old Sep 14, 2004 | 06:43 AM
yotafreakshow's Avatar
yup, how low is the psi?
Old Sep 14, 2004 | 07:49 AM
bigbear4's Avatar
Have to find my comp guage........I'd guess about 50 or so.
Old Sep 14, 2004 | 07:52 AM
bigbear4's Avatar
Not enough for ignition though.
Old Sep 14, 2004 | 08:01 AM
Nam's Avatar
Nam
50 is way to low...got to be over 100 for combustion.
Nam
Old Sep 14, 2004 | 10:12 AM
bigbear4's Avatar
I moved the chain one tooth...Made no difference......Head was cleaned, surfaced ...valves checked out good......Honed short block, new rings....all the rest are firing so well that when disconnected individually, engine dies. When I pull #1, no change.
Old Sep 14, 2004 | 03:47 PM
bigbear4's Avatar
OK....I seem to have adequate compression but cylinder doesn't fire.....pulled injector and applied 12 volts to it and it works.........Should I read 12 volts across injector plug contacts when running ?
Old Sep 14, 2004 | 07:40 PM
is the injector plugged? you said it works, does that mean you can hear it click when current is applied, or have you tested it with fluid under pressure. I'm visualizing an old turkey baster with a length of rubber tubing fit over the end of the injector that plugs into the fuel rail to apply the pressure. Then apply current and see if it sprays. I can see this creating a pretty major fire hazard though. I'm sure toyota sells some expensive test tools to do it more safely. Have buddy w/fire extingusher nearby! :fireman:
Old Sep 14, 2004 | 07:47 PM
AgRunner06's Avatar
You can see if the injector is firing by putting a screw driver on it and feeling it click. What does the spark plug look like after you've had it running? Is it wet? If not then the injector isn't spraying fuel. If it is, then you have a spark issue with that cylinder.
Old Sep 16, 2004 | 04:24 AM
bigbear4's Avatar
Is the injector supplied with 12 volts to fire or is the voltage constant and it is supplied with the ground? Thanx, Gary
Old Sep 16, 2004 | 06:17 PM
bigbear4's Avatar
Thanks For All Your Suggestions. I Found A Section Of Wire In Loom That Didn't Get From Point A To Point B !!!
Old Sep 16, 2004 | 06:19 PM
bigbear4's Avatar
Auto trans that shifts from first to fourth bypassing 2 and 3. Any ideas? 85 fourrunner
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
