22re intake manifold question
I found in my lower intake manifold, there is a chip next to the gasket. If i spray starter fluid in it, the truck idles perfect. Can i use any lower intake manifold to replace this or is it specific to my truck 94 22re (i know the intake design changed early 90s late 80s)
Ps does any one have a cheep intake manifold they wanna unload to me
thanks
thanks
lower intakes are all the same in the efi years, if i were you i would pull the upper off, and replace the gasket using a gasket sealer called plyable non hardning permatex, it should fill the hole and make an excellent seal, the only prob with it is when you go to take it back off, it will be a mess to clean, but hey its doing its job, and a helluva lot better than rtv
steve miller
Oct 10, 2015 01:40 AM
icentropy
Jul 14, 2015 10:23 AM
