22re?
Old Mar 17, 2007 | 02:53 AM
scenarioL113's Avatar
22re?
Is the 22re the 4 cylinder thats come with the 3 rd generation 4runner?
Or is it a different 4cyl motor all together.
Old Mar 17, 2007 | 03:42 AM
RustBucket's Avatar
the 3rd gens use a 2.7L
search.
Old Mar 17, 2007 | 07:50 AM
BajaRunner's Avatar
22re was offered until 95 I think. Its a kick ass engine though. I've never owned the newer 2.7L but, I hear its just as good.
Old Mar 17, 2007 | 09:48 AM
norcalsvx's Avatar
the 2.7l is a tough little motor
Old Mar 18, 2007 | 06:45 AM
I did search and it is just mentioned as a 2.7L.
I was wondering if it is the same "block", I want to know if it uses the same bellhousing as a 22re uses. Or if they are atleast compatible.
I am looking to do an engine swap and the bellhousing I am looking into is compatible with the 22re.
If the 2.7L is the same block or has the same bellhousing bolt pattern than I can utilize the 3 generation 2.7L transmission.
I want to do the swap into a 3 generation 4runner.
Old Aug 5, 2007 | 06:07 PM
ewong's Avatar
AFAIK the 22RE and 3RZ (2.7L used from 1995 to 2005) have different motor bolt patterns - or alot of things would be alot easier...
The 3RZ is becoming a popular swap/upgrade for the 22RE
The 3RZ used an W series tranny and thus the 3RZ bell will bolt to a 22RE's W56 transmission
reading between the lines - you want to swap a 2L series diesel into a 3rd gen 4Runner chassis?
If there is such a thing as a 2.7L 4cyl MANUAL 4Runner - then you could use the 22RE bell to mate the W (I think its a W59) series trans to the 2LT
Old Aug 5, 2007 | 06:11 PM
ewong's Avatar
Based on the other thread - just get any MANUAL 3rd Gen 4Runner and make a custom transfer cross member as necessary its not that hard.
Use the 2LT motor, the 22RE bell, an a 2.7L taco manual trans and transfer (that will give you the drivers side drop..)
Hmmm - gas tank and fuel lines are already on the "correct" side for this swap....
This is getting interesting...
Old Aug 7, 2007 | 01:29 PM
Adam F's Avatar
2lt in a 3rd gen? That motor only puts out 83hp and 139 ft/lbs of torque. That would be a downgrade from even the 4cy.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
