22r exhaust stud ?
Old Jul 28, 2004 | 01:08 AM
superjoe83's Avatar
22r exhaust stud ?
does anybody know if any of the exhaust manifold studs go into a water jacket, I'm asking this because i am going to replace my manifold gasket and if a nut were to get stuck on one if the studs and unscrew it from the head i want to know if water will be present, thanks
Old Jul 28, 2004 | 01:17 AM
2wd1stgen's Avatar
From what i can tell from the haynes manual, no water will be present.
Old Jul 28, 2004 | 01:21 AM
superjoe83's Avatar
thanks
Old Jul 28, 2004 | 01:24 AM
2wd1stgen's Avatar
loosen nuts and bolts holding manifold onto cylinder head work from the outside inward in a circle.
Old Jul 28, 2004 | 02:09 AM
superjoe83's Avatar
thanks again
Old Jul 29, 2004 | 07:34 AM
motorhead99's Avatar
i have an 89 that i just did the exhaust manifold and gasket... just remove the bolts and nuts.. and then remove the studs.. i found the old double nut method to be very effective... and personally when ya put em back on.. i would but new ones mostly because new stubs will be straight with no warpage from being a part of the exhaust system.. if i remember right they cost about 1.50 each.. and that will keep you from having miss torquing and causing you another leak..
rock on,
matt
Marsheen
Feb 17, 2016 12:29 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Fakayayou
Aug 9, 2015 12:47 AM
accuracy
Aug 6, 2015 12:32 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
