2002 4runner brake issue
Old Apr 23, 2008 | 06:20 PM
bryston's Avatar
i have a 2002 4runner, it has 100km on it, am going through 1 set of front router evrey 8000km, i can't keep up, the router warp to fast, the delear replaced them 3 times under waranty so far, now they are gon again, the car vibrate when i hit the brakes, what should i do? whats the tundra upgrade? should i try other blanks insted of the OME?
THANKS
Old Apr 23, 2008 | 07:46 PM
element's Avatar
It sounds like there is a bigger problem. A sticky of frozen caliper maybe? Pinched break line?
If your caliper is constantly clamped it will ruin an OEM or an aftermarket rotor.
Your post is a little unclear, are you only having problems on one side?
After three trips to have this repaired under warranty, what is the dealer telling you?
Old Apr 23, 2008 | 09:40 PM
cackalak han's Avatar
Like said above, I would get the dealership to replace the whole brake system--calipers, rotors and pads. No way it should be going through rotors that fast.
Old Apr 24, 2008 | 02:34 AM
bryston's Avatar
thanks for answer, the dealer replced them under warranty three times already, he told me he can finde nothing wrong, i cheked to see how long after in its about 10000km. i told him to see if anything wrong with caliper but he said thhey are ok(car is not under any warranty). any thought.
Old Apr 24, 2008 | 02:38 AM
bryston's Avatar
and yes, its both sides
thanks
Old Apr 24, 2008 | 04:55 AM
lobody94's Avatar
If you had them replaced 3 times under warranty. You should contact Toyota and explain your situation. This sounds like a special circumstance and should be honored since you have been having problems out of it. If you don't get anywhere with Toyota file a claim with the Better Business Bureau then Toyota will deal with you.
Good luck I have been through a similar situation and you have to let your voice be heard by someone other than the dealer.
Old Apr 24, 2008 | 05:10 AM
mkgarrison5's Avatar
doesnt sound right to me.. though 02 tacos and 4runners have had known braking issues... my brakes suck but not like his lol
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
merc1100sc
Jun 26, 2015 05:24 PM
Juan Manzione
Jun 10, 2002 04:12 AM
