2001 4runner SR5 nothing on # 2 ?
Old Jan 27, 2011 | 05:26 AM
2003mikem's Avatar
Ok I have enough experience with the 20R and 22RE
What should I look for first ?
I haven’t even opened up the hood yet.
Is this a common problem ?
135 K
Old Jan 27, 2011 | 05:45 AM
waskillywabbit's Avatar
Spark plug wires. Coil pack wires.
Did it just quit?
:wabbit2:
Old Jan 27, 2011 | 04:06 PM
2003mikem's Avatar
i check compression. none in #2, check it wiht my scope, hole in the piston.
what can i pull a 3.4 out of uesed and put in my runner?
will and 3.4 work ?
98 and up?
4runner ? tacoma? t100 ?
thnaks
Old Jan 27, 2011 | 04:52 PM
2003mikem's Avatar
Old Jan 27, 2011 | 05:05 PM
mt_goat's Avatar
The basic 5VZFE engine is the same but some of the things screwed and bolted on to it changed. I'd recommend you keep all the sensors and anything electronic from your current motor. The injectors may be a different size, MAF may be different, O2 sensors, wiring, exhaust manifold...etc.
Old Jan 27, 2011 | 05:13 PM
2003mikem's Avatar
so pretty much buy a sed 3.4 and just use the shrt block ?
keep all the thing from mine? lower intake all harness and all electrical ETC ??
Old Jan 27, 2011 | 05:18 PM
vital22re's Avatar
totally a bro
yes, you'd be buying a used 3.4 just for the long block (Block and heads). Have your injectors cleaned professionally. I wonder if a poor spray pattern burned the hole in the block
gary4runner
Sep 24, 2015 12:53 AM
88yodabasket
Jul 13, 2015 01:32 PM
mengquis
Jul 13, 2015 10:39 AM
Rkellerman
Jul 12, 2015 08:42 AM
