2000tacoma 2.7 4x4 5speed bucking
Old Jul 11, 2011 | 12:39 PM
240z's Avatar
okay this thing is driving me crazy and draining my pocket.starts bucking at 2300 rpm in 3rd gear continues till 3200 rpm I have replaced 02 sensor,tps,plugs,air fuel meter & have swapped out a known good maf sensor with no change.scanned the computer and no codes any one have any ideas or had a similar problem???
Old Jul 11, 2011 | 01:10 PM
Black_1985_SR5's Avatar
you check for an intake boot leak?
Old Jul 11, 2011 | 01:23 PM
240z's Avatar
yeah sprayed 2+2 around intake and boot .thanks anyway
Old Jul 11, 2011 | 02:02 PM
scuba's Avatar
Fuel pump and fuel filter?
Old Jul 11, 2011 | 02:58 PM
NwRunner's Avatar
When you replaced your TPS did you use a voltmeter to make sure it was adjusted to spec?
When did this problem start?
Old Jul 11, 2011 | 04:09 PM
240z's Avatar
I just purchased this truck, it had multiple problems ,the o2 sensor was flat lined and it failed emissions.replaced the o2 sensor and went through with flying colors but still had the buck. just got done replacing the fuel filter made no diff. how can you adj. the holes are not slotted
Old Jul 11, 2011 | 04:12 PM
240z's Avatar
just replaced the fuel filter wasn't clogged, no change it runs very stong through 1st and second gear
Old Jul 11, 2011 | 05:57 PM
scuba's Avatar
They don't need to be adjusted on a 2000. I know I didn't need to adjust it on my 99. I think they needed adjustment from 95.5-97.
ghostmoney
Jan 28, 2018 11:42 AM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
jake_v
Jul 22, 2015 03:17 PM
shadowbirdie
Jul 21, 2015 10:38 PM
HRDC0R19
Jul 5, 2015 06:43 PM
