2000 4Runner Sport - Transfer Case Issue? Wants to jump out of 2HI and GRIND/BANG BAD
Old Aug 12, 2018 | 12:11 AM
JustPrepping's Avatar
Recently purchased a 2000 4Runner Sport with just over 200k. Doesn't have the E-Lockers, regular J-Style/Manual Transfer Case. Was running just regular driving down the road in 2HI and out of nowhere it felt like I hit something, something METAL and BIG. Stopped and looked everywhere, nothing, drove it again slow and just started banging again super hard. Fiddled with it and figured it was in the transfer case. I can leave it in 4HI and it will drive just fine (Relatively speaking), but if I leave it in 2HI it will slip out of "Gear" "Towards 4HI" and just start banging. Its still in 2HI but trying to shift on its own. SUPER WEIRD. Wondering if anyone has had this issue and where I should start on troubleshooting/repairs. Dug around this/other forums and haven't seen anything quite like this, REALLY REALLY hoping for some direction. Thanks in advance.
Old Aug 12, 2018 | 03:22 AM
…. Anybody?
Old Aug 12, 2018 | 04:57 AM
Malcolm99's Avatar
Sounds like a bearing is toast, when the shaft moves due to play in bearings there is enough play to pull the synchro out of gear. Or the linkage is bent putting pressure on the shifter, or body is shifted putting pressure on shift rod,. On a manual transmission it is almost always a bearing that is toast causing the shifter to pop out of gear. Have you checked the 1L of fluid in the t-case yet to see its condition.
Old Aug 12, 2018 | 12:19 PM
millball's Avatar
There is little 'troubleshooting to be done on manual transfer cases, other than to remove and disassemble them.
Yours is telling you that it is seriously broken.
Old Aug 12, 2018 | 12:41 PM
fierohink's Avatar
As stated above, there isn’t a lot of troubleshooting to be done. You likely need a rebuild due to internal failure. That isn’t like a component that exhibits electrical malfunction having a table of trouble codes to diagnose.
You can try to narrow down the failure and possibly preorder some parts. Determine if when shifted to 4wd the front driveshaft turns. Do you get any noise in LO range? Pull the driveshafts and verify it to be coming from the transfer case and not say a blown pinion bearing in one of the differentials.
4wheelingyota
Aug 30, 2010 04:45 AM
ed4stoy99
Jan 7, 2009 12:31 PM
Toyojer
Mar 15, 2007 09:14 AM
943kgt
Nov 7, 2006 02:42 PM
