2" BL installed...pics
Old Oct 27, 2004 | 12:27 PM
  #41
Bigkahuna808's Avatar
I was thinking that so, do they sell thoes over at Home Depot?
Old Oct 27, 2004 | 12:28 PM
  #42
and what about lock-tie red???wont that stop the bolt from loosening? People use read to hold some crazy stuff together, might it work for us?
Old Oct 27, 2004 | 02:10 PM
  #43
midiwall's Avatar
Around here, Lowe's has a better selection of hardware than Home Depot, but HD "should"...
LockTite would be a possibility as well!
Old Oct 27, 2004 | 02:51 PM
  #44
keisur's Avatar
Originally Posted by <96 Runner>
I would also like to remind everyone to check the BL bolts and nuts often. I have found mine considerably loose on more than one occasion. I think the reason they start to loosen is because the factory bolt had a safety stopper on it and the bolts included with the kit do not (at least mine didn't).
Just a heads up.
I maded my own spacers and bought my own hardware, therefore I used grade 10.9 M10 zinced bolts and zinc nuts with the nyloc inserts for that very reason. the wad of harware only cost me $15 total since I bought them through my company. hehe.
diss izz where I got them out, ask for Clay if he's still working in the shop. Say "Roll Tide" to him and he'll get you hooked up with whatever you ask for. haha, he's a Bama fan!
http://www.carsons-nbt.com/
I also used a deep socket and hammered the safety washer (the one with the tab) off the stock bolts and put a lock washer between the new bolts head and the safety washer, this keeps the bolts from turning and allows you to use the stock safety as 96runner suggested.
Old Oct 27, 2004 | 03:03 PM
  #45
keisur's Avatar
Originally Posted by TStango
I picked up some composite trim materials at Home depot to fill the gap between the TJM and the body. If that works out it might be worth a write up.
I'd like to see how you guys make out with that rubber material to fill the gaps between the frame and body
I'd like to see the TJM gap cover you came up with, I too am disgusted at the big gap there. it you get a chance.
Old Oct 27, 2004 | 03:04 PM
  #46
keisur's Avatar
Originally Posted by midiwall
Hows about using a Nylock nut Christian?
see my post two up from here.
Old Oct 27, 2004 | 04:33 PM
  #47
fourunnabilly's Avatar
Guest
Thanks for all the info and help here guys. I talked with roger today and he is setting me up with a 1.25" BL for my 4th gen. The install appears to be a piece of cake, and i need that extra clearance for the 37's. I'll be sure to get some pics, etc...as I will be one of the first to do this to a 4th gen. We are also working out a 4th gen diff drop. Have a good one.
Anthony
Old Oct 27, 2004 | 04:44 PM
  #48
4runner4me's Avatar
I could not take looking at the towing package and the spare hanging down and had to take them off. I am going to get the crossmember raised if i ever get a chance. It doesnt look that hard if you just cut it loose and raised it 2 inches. I tried to flip my hitch just like you keisure but it was a little bit to wide. I drilled a hole in the grey bumper pad so that the crank would hit the hole. I got tied of pulling off the pad because I have a painted back bumper and it scratches the piss out of it. I was am going to use some black floor mats to fill in the body gap.
Old Oct 27, 2004 | 05:49 PM
  #49
keisur's Avatar
I thought about that when I was at Walmart a couple weeks ago but I couldn't find any that didn't have the funky impressions on them.
Old Oct 27, 2004 | 06:21 PM
  #50
BajaRunner's Avatar
Okay, heres the stuff I bought.
Well, I've already cut it out. These are just for the rear gaps.
I asked the guy at OSH about how durable it was. He told me: "Its extremely durable, it will NOT break down or tear". He actually had a hard time cutting it with the razor knife. I had to use my industrial scissors to cut it!
He also said that its real rubber, and "none of that plastic crap". Its really flexy and smells good.
It was on a big roll, labled: "rubber black matting". For the 3 foot wide roll, it was $5.70 per foot. So I ended up getting a 3'x2' peice, and I think I'll be able to get the front gap gaurds cut w/o any problems.
I bought some screws and will be fastening them on the rear that way. For the front, im just going to use the black snap-on tab things again. Im going to have to drill through this stuff though too.
Originally Posted by GreenRunner
Quick question on the 305/70/16s you ordered. Are you sure they'll fit on the stock rim? I'm assuming you have the 16X7 rim, because most people put this size tire on a 16X8 rim. And do you have the stock A-arms? The backspacing on the stock rims will most certainly allow the 305/70/16s to contact the stock A-arm.
Yes, your correct. You need to run them on 16x8 wheels minimum. You'll also need a wheel with 3.75" backspacing to clear the A-Arm. Unless of course you have some wheel spacers.
I just actually had to cancel my order. I'll probably end up going for 285/75/16's sometime. The 12.50's look too wide on the 4runner anyways IMO.
Old Oct 27, 2004 | 06:33 PM
  #51
keisur's Avatar
What-uh what is OSH? Orchard Supply Hardware? Since it's only in Cali I'll have to go uh-looking here in Greenville on Saturday for a comparable product.
Old Oct 27, 2004 | 07:34 PM
  #52
BajaRunner's Avatar
Yep...thats the place.
Just a hardware store, but, they got a lot of cool stuff
Old Oct 28, 2004 | 12:03 AM
  #53
Damn I wish I had that store here in Hawaii. I went to Ace hardware today, and nothing. I went to City Mill (Local Store) nothing from them. It looks like Im gonna have to go to Home Depot or Lowes. To look for rubber floor matting. Thanks for the info
Old Oct 28, 2004 | 05:48 AM
  #54
midiwall's Avatar
Check Home Depot and Lowes. I used that stuff to create sonic isolation barriers in a floor of a home music studio. It's real dense yet flexible.
It was a couple of years ago, but I found it at Home Depot... It was on a roll in an end-display, back around the linoleum flooring.
Old Oct 28, 2004 | 07:11 AM
  #55
BajaRunner's Avatar
Yes, that sounds like the same stuff.
I mean, Im sure there are several things that will work out there... I just picked the best stuff that I could find at the store!
Luckily, the guy also told me that it was real rubber and the stuff is indestructable.
I think the main characteristic of this stuff is that it has the ribbed side (for your pleasure).
The other side is smooth, almost glossy when new.
Lastly, it smells like a new toy.
Old Oct 28, 2004 | 07:47 AM
  #56
keisur's Avatar
uh, one that's ribbed of course?
Old Oct 28, 2004 | 08:07 AM
  #57
GreenRunner's Avatar
Nice pictures. Your 96' looks mighty clean from underneath. It's time to wheel that thing.
I just swapped out my 1" 4crawler BL for a 2" one this past Sunday. I could have used those boogie boards. The job was sooo much easier the second time around and air tools cut the install time in half.
I took care of the spare tire issue with the 1" BL by enlargening the whole in the body. I think I have an old picture on webshots linked to my sig. (I can't check here at work). I haven't had a chance to check & see if this still works with the 2"er or if it needs further modification. To do it right, I would like to raise the whole assembly like Schaeffer did.
I also want to do something about the hitch being so low. I hate that thing.
Got any new pics with the 2"BL?
Old Oct 28, 2004 | 08:39 AM
  #58
4runner4me's Avatar
yes, your correct. You need to run them on 16x8 wheels minimum. You'll also need a wheel with 3.75" backspacing to clear the A-Arm. Unless of course you have some wheel spacers.
You are right you cant put a 12.50 on a 7" wheel. But you do not need 3.75 bs to make it work with a 16x8. It actually works beter with a 4.0bs because you dont have to worry about hitting the arms or the out side of tie hitting fenders. I think with 4 or 5 inches of lift on a 3rd gen it looks to tippsy and skinny with 285's. I think the 305 is perfect. I also dont like that a 285 looks like it is 11.5 wide or that a 305 looks like a 12.50 when compaired to a 15 wheel.
this is a pic of my truck with 305 mtr's. Anything smaller is to skinny I think.
Old Oct 28, 2004 | 09:48 AM
  #59
keisur's Avatar
hmm. I have 285's and they stick out just as wide if not wider than yours do. mine looks fine and still has a wide looking stance even with the 5 inches of lift and 285's on 16x8 - 4.25" bs wheels.
have you fully flexed that thing with the 305's yet? I had to remove the rear mud guards and the front mud guards with my 285's or they would have been removed by the tire at full flex and the 305's and 285's aren't that much different in OD.
I also don't understand, are you saying you don't like that the 285's and 305's actually appear wider than they really are? because 285mm=11.2" and 305mm=12.0"
Old Oct 28, 2004 | 11:42 AM
  #60
4runner4me's Avatar
all I was saying was that when I had 285s my truck looked to skinny like it was top heavy. The 305 look much better in my openion. I think the reason that your wheels poke out as far as mine is because I have limited fares. That may also be the reason that 285 looked skinny. I realy hated how skinny it looked with the factory wheels 16x7 expecialy with that much lift and 285s.
I was saying that 285 dont look like they are 11.5 they look skinnyer. just like a 305 dont look like a 12.50 they look skinnyer. A 33 12.50 15 looks much wider than a 305/70/16 that was the point i was trying to make.
